Is this true!!!
Is this true!!!
My car has hard time starting up. It takes couple tries to get it started. Changed everything from the sensors to the starter, cleaned TB out still does it. Anyone know what the dealer say is true. Let me know.
Did you test your ignition switch?
Most of these nissan dealerships guarentee their estimates so Id be willing to say yah?
Get a second opinion.. BTW remove your address or someone might jack your car from the address above.
Proph
Proph
I don't think someone is really interested in jacking a car that has starting problems
I see the crank sensor replaced but what about the other cam angle sensor??
Looks like the tranny's main bearings might be going out. Used tranny time or pay $1,000+ for a rebuild + labor.
Proph
Proph
Thigs i replaced
battery
Ignition Switch
Camshaft sensor
Crankshaft sensor
Starter
Clutch
Knock Sensor
MAF
Spark Plugs
The thing is when it colds it hard to start. When its hot it takes 1 or 2 click to start. The thing is i can compression start it easily.
battery
Ignition Switch
Camshaft sensor
Crankshaft sensor
Starter
Clutch
Knock Sensor
MAF
Spark Plugs
Proph
Proph
They can take the car. I see alot of better cars. Hopefully the person thats gonna take my car likes pitbull.
Originally Posted by Jeff92se
Hmmm. Water temp sensor. Should be screwed in the head somewhere. That might affect cold weather starting
Crap its refreshing my mind now. I also replced the water temp sensor. Cleaned the whole air box with all the hoses. checked all my coils, wirring, etc etc. The thing about this is fishy is that my check engine comes on once in a while. It points to crank and cam sensor. Comes on and off. I had the sensors checked everything is fine. Funky
litch
123
01-04-2024 07:01 PM
TallTom
50
07-08-2022 09:54 AM
06-06-2017 02:01 PM
