Battery Replacement...
Old Apr 10, 2001 | 10:18 PM
iamit's Avatar
I have my car in the shop after an accident, and I was told that I should have the battery replaced. I have a 98 Max SE from about March of 98, and have nothing unusual to report for battery usage. I feel like it should last longer than this... any input or battery suggestions would be appreciated, Thank You
Old Apr 11, 2001 | 04:35 AM
Micah95GLE's Avatar
Did you see them test the battery with a load tester? That's the only way to know if it's bad or not.
Old Apr 11, 2001 | 11:01 AM
iamit's Avatar
even still...
if the battery really is low, could this be pointing to an electrical problem, or do they just die in three years just like that?... it's never needed to be jumped or used to jump another... Thanks for the input
Old Apr 11, 2001 | 12:32 PM
BRIGBOY's Avatar
Tell them this:
You want an optima yellow top battery for $100. No don't do that, well you could try, but I doubt they will go for it.
Just tell them you'll take car of it yourself. Throw some cables in the trunk and go on with your life. If it dies ever, jump it and then go get a new one.
Chances are you don't want the battery they will try and sell you anyways. There are better ones for similar prices incase you want to get a bigger stereo down the road.
Old Apr 11, 2001 | 01:45 PM
iamit's Avatar
cool
sounds like a plan... when i do need to get it replaced then, is there any benefit to going with more CAA? or should i stick with stock ratings. I know that the Maxima with cold weather package uses like 650 Cold Cranking Amps, but I don't have that package.. just wondering if it might help anything anyway
Old Apr 11, 2001 | 02:27 PM
Supa Lao's Avatar
I'm in need of a new battery. I'm just wondering what other guys and gals have in there car. Just shoot me some ideas.
Here's what I have:
'97
~1400 W stereo system.
I was thinking of a yellow top, but what else is out there? Any ideas on what my Cold Cranking Amps is? I don't have the cold weather package either.
Old Apr 11, 2001 | 05:16 PM
Micah95GLE's Avatar
I think that my mechanic said that the stock battery has about 350CCAs. That seems really weak, but mine lasted for all these years (108K miles) with LOTS of engine-off system blasting, so I would be surprised if one died after 3 years. But you might be better off getting a good 650CCA model anyway. That's what I did a couple of weeks ago when I finally killed the stock battery. Then you're set for a long time.
Old Apr 11, 2001 | 07:18 PM
iamit's Avatar
maybe i'm wrong....
but i don't think that higher CCA ratings will necessarily provide a longer life... in fact, I have a feeling that the electrical system as it is, might have trouble eventually keeping the battery at par from the alternator. Anyway, all the help is appreciated, Thank You.
Old Apr 12, 2001 | 04:42 AM
Micah95GLE's Avatar
Re: maybe i'm wrong....
But with more CCAs, using accesories with the engine off and starting the car will drain the battery less, since it has more to begin with.
Old Apr 12, 2001 | 05:19 PM
max808's Avatar
Check you water level...
I have a 99 GXE and my car wouldn't start yesterday. I added water, got a jump and it's back to normal. Bought a spare battery yesterday just in case.
Old Apr 12, 2001 | 05:45 PM
Micah95GLE's Avatar
Re: Check you water level...
If you let the battery run dry, it can damage one or more of the cells. Then it won't ever hold a charge. Good thing you have a new one.
Old Apr 13, 2001 | 01:48 PM
max808's Avatar
Re: Re: Check you water level...
I may have damaged one or more cells, can't really tell because my car seems to be starting normal again. I'll hang on to the new battery, just in case. Is $30 for a 550 CCA battery a good deal? Thanks.
Old Apr 13, 2001 | 04:20 PM
Micah95GLE's Avatar
Yeah, sounds like a good deal to me.
Old Apr 13, 2001 | 06:18 PM
max808's Avatar
Sam's Club
It was at Sam's Club. The brand was Champion, type 35.
gigabyte
Jan 6, 2017 06:05 PM
bigfrank
Oct 1, 2015 12:51 PM
markevans999
Sep 10, 2015 04:29 PM
