1107 -> A/T TCC SN FNCTN , what is this?
Old Oct 3, 2004 | 12:17 PM
bigx323's Avatar
got this code,, cant find a single bit of info on this.
What is TCC, i've heard it somewhere before but never knew what it was.
Can anyone help me with this one?
thanks
Old Oct 3, 2004 | 02:08 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
Diagnostic Trouble Code P0744 indicates a problem with the Solenoid Valve Lock-up Function. This malfunction is detected when the A/T does not shift into fourth gear position or the torque converter clutch does not lock up as instructed by the Transmission Control Module. The electric circuit is good but the A/T failed to lock up. Possbile causes include...
- Torque converter clutch solenoid valve
- Each clutch
- Hydraulic control circuit.
DTC P0744 is entirely consistent with P0734. It's no surprise to find both codes set. They are both warning of the same problem, so whatever fixes one will most likely fix the other.
09maxshawn11
Aug 9, 2015 01:13 PM
Mrsideways
Nov 2, 2002 05:15 PM
Ryan96gxe
Jan 10, 2001 11:00 AM
brittb
Jan 2, 2001 08:13 PM
