Broke a rear wheel stud. need help!
Old Apr 11, 2001 | 02:47 AM
SkyXRacer's Avatar
I got the rotors and caliper assembly off but i can't figure out how to remove the wheel stud. Do i hammer it out or what. Plz help.
Old Apr 11, 2001 | 04:51 AM
Daniel B. Martin's Avatar
Two methods
There are two methods. Both require removal of the caliper and rotor.
1) The "by the book" method.
Remove the hub. Use a hydraulic press with suitable fixtures to gently press out the broken stub and press in the replacement. Reinstall the hub. The disadvantage to this method is that it is time consuming and requires access to a press.
2) The way almost everyone does it.
Use a 3-pound hammer and suitable punch. Using brute force, pound out the broken stub. Put the replacement stud in the hole. Put four washers over the exposed stud. Put the lug nut on the stud backward (flat side toward the hub). Tighten the lug nut, and this will pull the new stud into place. Remove the nut and washers. The disadvantage to this method is that the hammer blows may damage the wheel bearing. The damage may show up weeks or months later.
Old Apr 11, 2001 | 08:20 PM
SkyXRacer's Avatar
Thanx
thank you
Old Apr 12, 2001 | 12:09 AM
party_boy's Avatar
dont pound the hell out of it
be gentle and slowly add force until it happens.
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
stromm
Aug 27, 2015 04:13 PM
twotonezed
Aug 16, 2015 11:41 AM
