flywheel install help
Old Oct 4, 2004 | 08:09 AM
nismomax98's Avatar
flywheel install help(fidenza)
im trying to install new fidenza and i dont have the torque specs for the flywheel bolts. Also do u use the spacer thats on the old flywheel with the new flywheel. any input would be great also any other things i need to watch for when doing this. thanx
Old Oct 4, 2004 | 08:23 AM
95_SE_5spd's Avatar
DO NOT RE-USE THE SPACER! i did with mine and i had to take the tranny out 3 times before i figured out that it was the problem. the flywheel bolts are like 63 ft/lbs, and make sure you use a criss-cross pattern when tightening them.
Old Oct 4, 2004 | 08:24 AM
Stephen Max's Avatar
I just installed my Fidanza over the weekend, so the torque numbers are fresh in my mind. The specified torque is 50-59 ft-lbs. I set the torque to the high number.
I did not use the spacer thingy. I read in a thread last week about a guy who had problems with clutch engagement when he used the spacer. His problem was solved when he removed it.
Now's a good time to replace the clutch and throwout bearing. I didn't because I have 40,000 miles on the ACT clutch, and I figured it had at least another year of life left. After looking at the clutch plate, I wish I had bought a new one.
Old Oct 4, 2004 | 09:45 AM
nismomax98's Avatar
i didnt use the spacer thing but when i tightend the bolts the flywheel was too far on the shaft and there was a space between the bolts and the flywheel so i figured i need the spacer help anyone thanx
Old Oct 4, 2004 | 10:13 AM
That's interesting. I am still using the flex plate bolts left over from when my car was automatic. The bolts are about 3/4ths the length of the flywheel bolts, so I didn't have any length issues like that from not using the spacer.
Old Oct 4, 2004 | 11:18 AM
nismomax98's Avatar
help anyone had this problem
Old Oct 4, 2004 | 11:42 AM
The problem of your bolts being too long? Get flex plate bolts for an automatic transmission from your dealer, or a junkyard.
MaxLife17
Jun 27, 2019 01:37 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
catalinvint
Sep 16, 2015 07:48 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
