Help With Tranny Cooler Installation
Old Apr 11, 2001 | 02:06 PM
SB97MAX's Avatar
Ok I had problems posting the pic lastime and since the title was bad I deleted it. Here is the new one. Now can someone tell me what the piece next to the black round pieces is where it goes and what it does? Also do the black round pieces go in between the foam and the Tranny Cooler or in between the A/C Condenser and the foam? Last question, How much Tranny Fluid do I add when IM done and what brand should I go with? Thanks
Old Apr 11, 2001 | 02:09 PM
SB97MAX's Avatar
Sorry the pic is small, thats the only one it would let me post.
Old Apr 11, 2001 | 02:25 PM
MAXDriver
Assuming car's facing left
Front of car - ZIp tie -tranny cooler -foam- A/C condenser- black round plastic piece to secure zip ties.
You mean the piece that looks like a metal tube with the compression nut ? You don't need it.
Hope this helps.
Old Apr 11, 2001 | 02:29 PM
SB97MAX's Avatar
Thanks that did really help and I appreciate it!!!! Do I just leave the end of the Zip ties sticking through there or do I cut them to make them shorter? THanks again for the help!!!!!!!!
Old Apr 11, 2001 | 02:44 PM
MAXDriver
I cut mine. Oh you'll need to add 1/2 quart of AFT after install. I use Nissan D.
Old Apr 11, 2001 | 02:45 PM
MAXDriver
Glad I could help. I cut mine. Oh you'll need to add 1/2 quart of AFT after install. I use Nissan D.
MaxLife17
Jun 27, 2019 01:37 PM
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
Lowered_a33
Sep 1, 2015 07:49 PM
