Anyone with LEDs in heat vents?
Old Oct 6, 2004 | 07:52 PM
hollaatchaboi's Avatar
If i bought the special 12 volt led's how would i go about wiring this? Also, how do i wire neons to a switch? I know on the switch that you connect the power, the ground, and the positive of the neon, what do i do with the negative of the neon? Any write-ups?
Old Oct 6, 2004 | 08:16 PM
aspec0002's Avatar
u ground out the negative, if you wanted you could ground it to the same location as the switch
Old Oct 6, 2004 | 08:24 PM
ny96max's Avatar
i would wire the LED's to the illumination wire (+) and (-) dimmer wire off either the hazard button or the rear defrost button. Using the (-) dimmer wire will allow you to dim the LEDs using the dimmer switch.
Neons if you want the easiest way... go to the cigarette lighter and use the switch on the (+) lead.
Ant
Old Oct 6, 2004 | 08:27 PM
Maxima99SE's Avatar
will fly for food
manualmaxima did that
Old Oct 6, 2004 | 08:32 PM
For ground, i can use a screw correct?
Old Oct 6, 2004 | 08:34 PM
Ant
Do you know which wires these are? What color are they?
Old Oct 6, 2004 | 08:35 PM
any other power source for the neons? Don't want to burn out the cigarette lighter.
Old Oct 6, 2004 | 09:39 PM
also.....for the neons, where in this connection could i put an inline fuse?
Old Oct 6, 2004 | 09:44 PM
acidmeld's Avatar
yeah, ive got em in my car. theyre the cheap ebay ones but they work. (lights) i just ran a line from the positive terminal through the quarter panel and the rubber seal for the door wiring to the interior by the fuse box. i drillied a small hole in the kick panel (where it wouldnt get kicked) and mounted a generic toggle switch there. getting the leds into the center vents isnt hard but the outside vents are a pain in the a$$. to get to the passenger side vent you need to remove the glove box and loosen that side of the dash. the bolts are easy enough to spot, not so easy to undo. pull on the dash and the vent will slide out of the piping enough to get the led in there. drivers side is almost the same process. i havent slept for two days so i apologize if this seems a little jumbled. any questions just ask.
Old Oct 6, 2004 | 09:48 PM
nyautostyle's Avatar
isnt there airbags u could mess up when you are taking out the pieces??
Old Oct 6, 2004 | 09:51 PM
acidmeld's Avatar
its remotely possible... remove the fuse for the airbags to be safe if you want.
Old Oct 6, 2004 | 10:22 PM
I wouldn't go through all that trouble, I'd just put them in the center vents. I just want to know as NY96MAX said, which wires can i connect them to from either the hazard lghts or rear defroster. Acidmeld, do you have any pics?
Old Oct 6, 2004 | 10:44 PM
acidmeld's Avatar
sorry, no pics. the illumination wire (+) is the red/blue wire and the dimmer wire (-) is the red/yellow wire. wiring it to these will allow the lights to be used in circuit with the lighting system. the leds will be on when the lights are on and will dim with the other lights. i just wired mine up with a toggle switch. never thought about doing it like this til now. im getting my info from the haynes manual wiring diagrams. i think i might redo mine tomorrow
Old Oct 6, 2004 | 10:48 PM
thanx! Will be attempting this also soon.
Old Oct 7, 2004 | 06:35 AM
ManualMaxima's Avatar
5th Gen till she dies!
yea i got that, i will post pics later cause cardomain is sucking at the moment. I have under dash neons and i just tapped them for power and ground, they run through a switch so the led turn ioff and on with the neons on the switch.
Old Oct 7, 2004 | 09:04 AM
is there an easier way to get to the outer heat vents?
Old Oct 7, 2004 | 02:20 PM
what do you mean heat vents> do you mean like this?
Yea i knlw they were dirty, but i cleaned them
Old Oct 7, 2004 | 02:25 PM
Exactly.....but how do i put them in the outer ones? Manual Maxima, how did you do that, you took the vent apart and drilled a hole for the LED? You have a write up?
Old Oct 7, 2004 | 06:32 PM
i do not know how to get themin the side vents but i am going to attept it next wekk maybe. this you do not have to drill holes. there are already holes there. i bought a pack of 3 led's at auto zone that had wires and resistors already attached, so all you have to do is stick them in the holes and hook them up to a 12 volt source.
Old Oct 7, 2004 | 07:32 PM
TJ_Max's Avatar
Paradox Systems Vendor
yeah ive seen those pack of 3 leds. i didnt think they would look that good though, nice job there....ill be doing this over the weekend....
did anyone try the door handles yet? and the panel for auto trannys that indicate wut gear ure in?
like this guy did it all:
Old Oct 7, 2004 | 08:03 PM
jdm71488's Avatar
the picture gives you your answer... i think...
Old Oct 7, 2004 | 08:12 PM
yea he had led dome, cup holders, and everything.
the gear shifter yea you can do that easy. i did it in my girlfriends altima
Old Oct 7, 2004 | 10:32 PM
aspec0002's Avatar
the door handles, ive done, its really simple just drill a hole in the desired spot and place them there and glue them in, then run the wires.
Old Oct 8, 2004 | 07:48 AM
aspec0002.....run the wires to where? What power source?
Old Oct 8, 2004 | 07:49 AM
TJ_Max's Avatar
is it easy to wire them to the door lights? just splice into the connector right?
Old Oct 8, 2004 | 07:52 AM
TJ_Max's Avatar
you changed the color of the lighting underneat? my P,D,N,R (WHATEVER U CALL IT) LIGHT UP WHITE...CAN U GIVE ME A LITTLE WRITE UP ON HOW TO GET THOSE TO LIGHT UP WITH BLUE LEDS OR SOMETHING? IS IT TOUGH TO GET IN THERE?
AND ONE BIG COMPLETELY NOOB QUESTION, AND I KNOW THIS IS DEALING WITH VOLTAGE, AMPS AND CURRENT, BLAH BLAH, BUT YOU CAN ONLY PUT 1 12 VOLT "APPLIANCE" IN URE 12-V CIG LIGHTER? I WANT TO WIRE THE HEAT VENT LEDS TO MY CIG LIGHTER, AND SOMETHING ELSE THERE AS WELL....
Old Oct 8, 2004 | 08:51 AM
that si where my led in my vents are wired to.....my cig lighter. the cig light powers my underdahs neonsand the then the leds take the power form the neons. also if you are goig to get led off ebay go with cwithk he is a very good seller and includes resistors.
Old Oct 8, 2004 | 09:21 AM
TJ_Max's Avatar
sounds like a plan, ive got my underdash neons from my cig lighter on a switch, ill take the power from the neons to the led, this way the switch controls the leds in the heat vent....good....and im getting the autozone leds for the heat vents since i cant wait....
Old Oct 8, 2004 | 07:04 PM
I tried to wire it to the illumintation wire off of the hazard light, however, it didn't work. Now, the hazard light and the rear defroster light don't work. The buttons still function however. What do i do? I didn't cut any wires, I used phone wire taps. How can i check why the lights of the buttons don't work?
Old Oct 8, 2004 | 11:30 PM
i dunbohow but i have 2 extra for sale if you need them.
Old Oct 8, 2004 | 11:53 PM
MDeezy's Avatar
a lot of good info here, gave some ideas on puttin some leds in. didnt know autozone has a 3 pack.
Old Oct 9, 2004 | 12:37 AM
aznprid972's Avatar
the light where the gear selector is lighted up by a #194 bulb. i think it'll be easier to buy an inverted #194 bulb and put it in there.
Old Oct 9, 2004 | 07:02 AM
TJ_Max's Avatar
an inverted 194 bulb.......i dont know what that is....can u explain? i know the 194 bulb part, just dont know wut u mean by inverted.....i want them to come out blue....and is it easy to get in there? ive removed the center console before and took a peek i couldnt find the bulb....thanks...
Old Oct 9, 2004 | 10:49 PM
I connected the LEDs today into my heat vent. It looks hott. I used the the wires from the hazard button as a power source. However, I am still confused, the buttons function and there is power going to them, but how come the light of the hazard button and the rear aren't coming on (the light of the picture)? Anyone have a clue.
Old Oct 10, 2004 | 01:02 AM
aznprid972's Avatar
inverted bulb as in the led one that shine at a wider angle. the bulb should similar to this...
and for the location of the bulb.. did you remove the center console as in the one where you rest your arm? it is held down by 4 screws. you would need to take the trim around the shifter off first, then you'll see 2 screws. the other 2 are in the back of the console. to remove the console, you must pull your ebrake all the way up and then you have to tilt the back end of the console up high enough to get the ebrake handle through. once that's out, you can see where the bulb under the shifter is on the driver side easily. it is removed by just a twist and it comes out. if you really need a pic, i can tear apart my car and take a pic for u tomorrow if i have time.
Old Oct 10, 2004 | 03:14 AM
TJ_Max's Avatar
cool thanks, i dont think i need the pic yet, if i run into problems tomorrow, ill tell u....thanks for the info man
Old Oct 10, 2004 | 03:16 AM
TJ_Max's Avatar
the pic on my hazard button hasnt lit up since i did the clock mod i think....id be interested in knowing some solutions to getthing this lit back up....
Old Oct 10, 2004 | 08:53 AM
are your door switch lighting up?, did you cut the right wire cause i think those harnesses the buttons run off of also have somhting to do wuth the clokc power. i am not sure, but it hink they do.
how would you do cup holder led's? you cannot just slap an led in there cause they yuou coule nt put a cup in it. what would you do?
Old Oct 10, 2004 | 10:10 AM
Now i recall i did the clock mod also. I'm assuming that's what the problem is. My window switches do light up. As for the cup holders, I would drill a small hole in the space in between the two cup holders. You can't really put it inside the hole of the cup holder.
Old Oct 10, 2004 | 11:50 AM
TJ_Max's Avatar
you cna never really get that clock true blue, no matter how much cellophane u put, im just gonna leave the magenta cellophane and make it white....as for the cup holders.....hmmm....im not sure how that would look, i think LEDs look best when they are hidden behind something emitting the light onto something else...ive got three switches in that space between the cupholders....its an easy way to get tot the cig lighter....but i have my two strobe switches and underdash neon switch in that area
