RPM Summit Switch install
Does anyone have a write up of how to set the rpm summit switch? I remember reading that nealoc i think has a write up.. But i am yet to find it..
http://store.summitracing.com/defaul...Ntt=rpm+switch
put this in for part number search..... SUM-830449
Andrei
Originally Posted by Zipp028
yes i have the mevi in but i have a rough idel.. and it stalls out.... thats my only problem.. i havent put in the summit or the solinoid or the vaccum in yet...
you most likely have a big vacuum leak...are you sure the MAF is pluged in?
The summit install is straight forward. Tap of the ECU for the rpm signal. Get power from either the battery or a source like the cig lighter fuse. The activation wire goes to the solenoid, and the ground goes to ground. The grey wire is not used
Originally Posted by AntiVelvet
When you say tap the ecu, do you mean open it up or just cut into one of the wires coming from it? If its just a wire which is it? color?
MaxLife17
Jun 27, 2019 01:37 PM
, well if will someday need to know this info (I'm getting my too)...so... bump
