gauge problem again!!! help
Old Oct 9, 2004 | 03:29 PM
blkhawk500's Avatar
Ok me again... It seems I have some bad luck when it comes to modding.
I tried doing the LED needle mod and it worked, but I notice that my gauge meters didnt work at first. Then after I rode over a bump they would work. So I opened the custer back up to see if something was loose and then plugged everything back in and now the metters dont work. The lights and indicators work fine but the needles dont move. Also the odo background display lights up but the there is no letters or numbers.
I was wondering if anyone knows if there is a seperate fuse for the metters or if anyone knows wht might be the problem.
Old Oct 9, 2004 | 05:57 PM
Poor Man's Max
sounds like you basically ****ed your gauges, happened in my dads old max, id go look for a junkyard, otherwise keep askin, cuz i cant help past that
Old Oct 9, 2004 | 08:03 PM
blkhawk500's Avatar
damn...I also just noticed that my remote starter is messing up...problem becuz the tach isnt working.
Old Oct 9, 2004 | 11:08 PM
OneToughMax's Avatar
the tach sense wire should still read fine, it's just the gauges that are fcuked up. the tach only displays the signal that is sent to it. that gauge not working shouldn't have anything to do with your remote start at all...
Old Oct 10, 2004 | 06:21 AM
blkhawk500's Avatar
do I have to change the whole cluster or can I just change the speedometer, since it seems that the other gauges lead off from that.
Old Oct 11, 2004 | 09:39 AM
nismomax98's Avatar
i had the same problem i took the cluster off and with my fingers pulled up on the needles to loosen them up and it worked except for my gas gauge. also did u plug the thin strip thats above the speedo gauge if u didnt nothing will work so check that
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
BrandonCause
Sep 14, 2015 10:41 PM
kadespraggins
Sep 14, 2015 12:04 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
