ECU Reset
Old Oct 11, 2004 | 10:27 AM
JetBlackMax83's Avatar
ECU Reset
any body know of another write up on reseting your ECU the link on here is broken never done it so i dont know ::shrug:: help would be appreciated thanks in advance pm me if you want
Old Oct 11, 2004 | 10:30 AM
Jumbo™'s Avatar
My Maxima thinks your Maxima is HOT!
Try this link: http://www.brianv.net/mods/ecu/
Old Oct 11, 2004 | 10:38 AM
maxima_kid's Avatar
Or you could just unplug the battery for a few minutes ...
Old Oct 11, 2004 | 10:52 AM
unplugging the battery resets the ECU?
Old Oct 11, 2004 | 03:08 PM
maxima_kid's Avatar
It should. No power, no memory I guess.
Old Oct 11, 2004 | 03:35 PM
chuckie311's Avatar
if it was that easy then they wouldnt have put in the screw in it to reset it.
Old Oct 11, 2004 | 04:30 PM
ThurzNite's Avatar
FSM says unplug for 24hr to reset.
Jae
Old Oct 11, 2004 | 04:45 PM
Maximus_95's Avatar
read the sticky meng. they tell you how to do it.
Old Oct 11, 2004 | 04:47 PM
Terran's Avatar
Turn screw fully CW, wait 2sec, turn CCW, wait 2 sec, repeat once and it should be done.
Here's a full CEL writeup http://vbxmaxima.8m.com/ecu.html.
I was under the impression that the above method cleared the codes, while the battery way cleared everything the ECU has learned about your car/driving habits.
Old Oct 11, 2004 | 05:36 PM
SlackR237's Avatar
Rollin' on 'Caps
I don't think it resets the ECU when you unplug the battery... Maybe ThurzNite is right about the 24 hr thing...
I just installed my new CAI saturday and I obviously had to unplug the battery. As soon as I plugged it back in, the CEL was immediately on for the vehicle speed sensor (something that takes about an hour of driving to come on normally with an ECU reset).
Old Oct 11, 2004 | 06:05 PM
Nismotic's Avatar
Always sunny in philly
Unplugging the battery for a bit does reset the CEL light (only of course if the problem has been corrected)
Old Oct 11, 2004 | 09:20 PM
maxima_kid's Avatar
Import Tuner
Sept Issue '04 pg.102
'03 WRX pt2
"dyno notes : The easiest way to reset the ECU is to
remove the negative terminal of the battery for about
a minute. Make sure the key is out of the ignition when
you remove the terminal and when you put it back on."
http://importtuner.com/tech/0409it_ppwrx/
Its that easy ...
You dont think ...
Maybe its 'obvious' you installed it wrong ... and you just got around to installing one? ...
I bought my Max in March
Blow Me ... non-believers
maxima_kid's Avatar
Oh yea, thanks for backing me up by the way.
Old Oct 11, 2004 | 09:24 PM
my99maxisnice's Avatar
Hey maxima_kid,
Don't you think that is a little too much piping for a CAI?
Old Oct 12, 2004 | 09:17 AM
JamesNH's Avatar
i hope your joking and dont see the turbo
Old Oct 12, 2004 | 09:33 AM
I was kidding.
Old Oct 12, 2004 | 04:53 PM
maxima_kid's Avatar
Yea, Im pretty sure that was sarcasm ...
You were being sarcastic right ? ...
Old Oct 12, 2004 | 05:15 PM
hey thanks guy rewired the speed limiter wire back together since i reasoned how often do i get the chance to go over 100 besides thats just asking to take my max away besides i didnt want the aggrivation of dealing with the check engine light and i didnt think it was worth it to run a switch and do all that work just to go over 100 kinda dum so i hooked it back up and reset it
Old Oct 18, 2004 | 08:22 AM
ThurzNite's Avatar
My speed limiter kicks in around 118. Why's yours kick in at 100?
I'm just typin out what the Factory Service Manual says. 24hr has worked for my other nissans, but never tried it in my 97 Maxima yet.
Jae
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
220k+ A32
Sep 22, 2015 03:08 PM
Colossus
Sep 9, 2015 05:46 AM
