Fuel Injector O ring Replacement
Old Oct 12, 2004 | 04:43 AM
vincej's Avatar
I am finally going to tackle replacing some bad fuel injectors. I picked up some used injectors that spec out fine. I want to replace the two O rings on each injector. The injector has a small plastic cap with 4 prongs that holds the lower 0 ring in place. It seems that the only way to remove the O ring is to remove the cap.
- On a couple of the injectors the cap is cracked. Any idea where I can get new caps? I read somewhere that someone makes a seal kit that includes new caps.
- Is it possible to remove this cap without cracking it? If so then I can remove them from my old injectors.
Vince
Old Oct 12, 2004 | 10:17 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
mobil one synthic grease around the rings, and then just use a fork to nudge out the ring.
kjlouis
Nov 24, 2018 06:09 AM
Cotozic
Jun 28, 2017 08:01 PM
Finkle
Sep 27, 2015 09:53 PM
Slamrod
Sep 3, 2015 07:38 PM
Balkins
Aug 12, 2015 06:39 AM
