resetting ECU
you take a flat head screwdriver.
Twist the screw all the way to the right for 5 seconds
Twist to the left all the way for 5 seconds
Twist back to the right all the way for 5 seconds
Twist all the way to the normal position(left)
Easy as can be dude i just did mine on tuesdayturn the ignition key so that you window switchs work but car is not running so just the electric is on drivers side floor kick plase on the right of the gas pedal take off the cover and you will see a screw cover with a clear plastic sticker unpeal the clear plastic turn the screw clock wise all the way till it stops wait 5 seconds then counter clock wise till it stops wait 5 seconds then again clock wise wait 5 seconds then counter clock wise wait 5 seconds then turn the ignition off then turn the car on ecu should be reset
lol hold on im gonna try to find the info for u for now try dis
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. Fully depress the accelerator pedal (HARD).
2b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 second.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
In case you need a new ECU: www.car-part.com - ~150 bucks.
Originally Posted by superblack99
the screw fell in the hole though
here is a write up hopfully this solves all your troubles.
http://vbxmaxima.8m.com/ecu.html
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
220k+ A32
Sep 22, 2015 03:08 PM
