Need a mechanics input
Old Oct 17, 2004 | 03:30 PM
tomservo291's Avatar
Yesterday i cleaned my TB and discovered the wonders it does. I cleaned my moms jeep this morning, and just a minute ago i did my brothers car (my old car, a '94 1.8l eclipse.)
For years since we had the eclipse it has started horrible, immediately dropped way below idle and would almost stall, headlights, brakes, anything that used power would basically choke the car to death. Apparently, this dirty TB (it was REALLY freakin dirty) was the direct root of these problems. After cleaning, the thing started w/out a flinch in a fraction of a second and idle'd like a pro.
But, it idle'd at 2000 rpm! It's not going down either, the idle is staying at 2 grand. I might consider it to be normal on a cold start till it warms up, but not while its warm.
My question is, is it possible that the ECU might have made sevre adjustments to try and fight this problem for the longest time, that now that it was instantly fixed that the throttle is set way too high for the idle? I don't know if thats possible, but if so, would resetting the ECU possibly fix the problem?
I know this isn't maxima related but I was hoping someone might care to lend some insight
Old Oct 17, 2004 | 03:53 PM
Terran's Avatar
I'm no mechanic, but it wouldn't surprise me. My idle went up when I cleaned the TB and I believe other's have posted about that side effect too. Never anything that severe, but if it was really bad maybe it could have change it that much. I don't know anything about the eclipse, but look on the max near the TB for the Idle Air Control Valve (IACV) it has this round plastic screw thing that can be used to adjust idle speed. Then maybe you can find something similar on the eclipse.
Old Oct 17, 2004 | 04:03 PM
njmaxseltd's Avatar
Give it a day or so of normal driving and see if the idle returns to normal.
Old Oct 17, 2004 | 04:11 PM
JP11283's Avatar
My throttle body was just cleaned out and my car idles around 1000-1100 rpms now. This is my first day driving it so I hope it comes down soon.
Old Oct 17, 2004 | 07:51 PM
acj's Avatar
acj
Usually after driving for a while the ecu should be able to compensate for the adjustment. If not, you could just disconnect the battery for a few minutes. It may run a little rough after reconnecting the battery, but it should clear up within a few minutes of “normal” driving.
I haven’t had too much experience with an Eclipse, but I know from experience that some vehicles (fords) can take forever to adjust to new changes. So if it comes down to it, just give it some time. (Or bring it to me, I could always use a little $$!!)
Old Oct 17, 2004 | 09:19 PM
ohannon7's Avatar
ecu's adjust, thats what they do. id reset it. if it dosent work then adjust the idle back down to where you want it after driving it for a week
Old Oct 17, 2004 | 09:50 PM
A32Matt's Avatar
did you disconnect the throttle position sensor? cause if you do it will make your car idle around 2000 rpm if you can get it to stay running at first.
Old Oct 18, 2004 | 12:10 AM
Prophecy1's Avatar
ECUs learn as they go, also the throttle position sensor is a good tip. Check your connections.
Proph
Old Oct 18, 2004 | 07:07 AM
nick's Avatar
your base idle is high because you have just dumped whole lot of highly flamable liquid into your intake mainfold. I will come back to normal within few days
Nick.
tarun900
19
Dec 20, 2021 06:57 PM
gigabyte
Jan 6, 2017 06:05 PM
D Mason
Jun 21, 2016 04:43 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
