Problems when starting
Old Oct 17, 2004 | 04:23 PM
Mymax97's Avatar
Hi
Every so often when i start my max it starts then the rpms go to 1500 rpms then goes down to like 200 and if i dont give it some gas it stalls out. Do you know what I could do to fix this. I think i read that someone cleaned their TB and then it fixed that prob, but do u think if that doesnt work i might need new spark plugs. Also im having problems when my auto is shifting its alittle jerkey. If you know anything that could help please let me know.
Old Oct 17, 2004 | 04:29 PM
tomservo291's Avatar
this is my new favorite answer to all questions, i just did it myself yesterday. yes clean the tb!
infact, if you look i just had a question about it when i did it to my brothers car because of your exact problem. my old car, which is now his, is a '94 eclipse which has always done what you describe. nearly die upon starting; after cleaning the tb (it has been like it has for years and years) the problem was instantly fixed.
it started better then it ever has, and idle'd like a pro with no power loss. however, we're trouble shooting the high rpm's it has at idle right now (dont worry, its because it was so messed up for so long the ecu has to adjust. you shouldnt have this problem, but if you do get a high idle you can drive around for a day or two to see if it adjusts, then you could reset the ecu or adjust the iacv (plastic screw next to tb that adjusts idle)
Old Oct 17, 2004 | 04:31 PM
Mymax97's Avatar
Hi
cool thanks so much for the help. Do you think that new spark plugs will help too?
Old Oct 17, 2004 | 04:32 PM
Mymax97's Avatar
Hi
cuz i have close to 100k and i dont really know what the guy had done with the car when he had it i just got it in Aug and jsut recently found out about this site. Do u know any 100k mile services i should do?
Old Oct 17, 2004 | 04:36 PM
i dont think spark plugs would cause the idle to drop really low then be normal afterwards, but weak plugs could be a contributing factor.
get ngk coppers (napa has them listed as ngk v-power copper or something similar) for less then $2.00/ea.
the car comes stock with double tip platinum ngk's, they last 60k mi. a dealership will tell you that's all it can use, and on the forum its about 70% copper 30% plat i would say from reading plenty of posts about them, about what people use. the coppers only last 30k but at a fraction of the cost, and in my personal opinion i would rather use copper since it is a better conductive material then platinum. (maybe thats why the plats need two tips and run identical to the single tip coppers?)
might as well do that while you're at it, plugs = $12, tb cleaner = $2.50, so for under $15 and some elbow grease your engine should be running like a pro
Old Oct 17, 2004 | 04:45 PM
Mymax97's Avatar
Hi
Thanks for helping out!!
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
