throttle
Old 10-18-2004 | 11:58 AM
9maxima5's Avatar
throttle
How do you tighten the throttle cable?
Old 10-18-2004 | 12:26 PM
PTownMax's Avatar
I still miss the max
i too would like to knw this, mine seems pretty loose right now and i think it might help with the problem i'm having
Old 10-18-2004 | 12:34 PM
blkmaxz95's Avatar
You can loosen the two nuts from the throttle cable. You will see two cables, the one inside is the throttle cable...closest to the firewall...the other...closest to the front of the hood is the cruise control cable. ... there is a thread some where on this subject...
Old 10-18-2004 | 12:39 PM
PTownMax's Avatar
do they need to be tight? Could that effect the car's idle?
Old 10-18-2004 | 12:46 PM
maxlauj95's Avatar
If too loose or too tight it does effect, best way is start the engine and adjust the cable bewteen 700 and 1000 RPM. To tighten tthe cable turn the nuts clockwise or the other way, i think but try both, i think is one of the two way when u turn it.... I did mine like a couple weeks ago.
Old 10-18-2004 | 01:13 PM
PTownMax's Avatar
ok loosened bolts and all it adjusts is the mounting position, the cable is still just as loose
msellas
09-23-2015 09:16 PM
220k+ A32
09-23-2015 03:38 PM
bumpypickle
09-20-2015 08:22 AM
conansriver
09-16-2015 12:17 PM
Bonka
09-14-2015 11:18 PM
Quick Reply: throttle
