Stripped the Radiator drain screw
Old Oct 18, 2004 | 03:56 PM
wabadooo's Avatar
Hi, does anyone have any good ideas? I completely stripped the plastic radiator drain screw on my 95 Maxima. I am thinking of trying an ez-out, but am worried because it is plastic.
Old Oct 18, 2004 | 05:13 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
i dont think its plastic, its rubber i think.
Old Oct 18, 2004 | 05:22 PM
MDeezy's Avatar
wow how did you do that? I think it is rubber too, if you have a junk yard around you should be able to go there and gank it off.
Old Oct 18, 2004 | 07:47 PM
Max Noob's Avatar
i stripped mine too.. but dont worry.. on the opposite side of the radiator is the main hose that leads to engine. make sure the car is cool. if you have a good grip then just unclamp it and let the coolant flow.. wimpier/smarter method is to some pliers. you'll never need teh drain plug again.. it drains faster this way too.
-i wouldnt try to force it out unless you have a replacement. the rubber is probably so beat by now if you try to plug i back in after forceably removing it, it will leak afterwards.
Miket2006
Mar 1, 2021 03:55 AM
Forge277
Jun 13, 2016 09:26 PM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
sliptap
Sep 30, 2015 05:57 AM
