Cefiro Install Help
Old Oct 18, 2004 | 04:57 PM
Nick7455's Avatar
Cefiro Install Help
I'm in the middle of installing these now and have made all the neccessary cuts but the headlight sticks out on both side....I know there is a gap but these are sticking out on both sides....whats the deal? any help is much appreciated!
Old Oct 18, 2004 | 05:10 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
cut deeper.
Old Oct 18, 2004 | 05:31 PM
Nick7455's Avatar
I cut further than in the pics.....hmmmmmmmmmmm...i dunno what else to do and its gettin dark -_-
Old Oct 18, 2004 | 05:59 PM
95bkackmax18s's Avatar
just keep cutting and a hammer with chisel kind of thingamage will work too, i had the same kind of problem and i wouldnt stop until it looked right.good luck
Old Oct 18, 2004 | 06:04 PM
nadir_s's Avatar
vicodin ... gift of life
keep cutting lol.
Old Oct 18, 2004 | 08:04 PM
Nick7455's Avatar
2 last questions...how did you secure your grille and make it look good at the same time and can someone take a pic of the wiring or tell me which color goes to which...i hooked it up and I think one is way too bright..prolly mixed the BIRGHT wire with the reg light wire.
Old Oct 19, 2004 | 02:43 AM
Nick7455's Avatar
bump...or does anyone have a copy of another install other than redmax one?
Old Oct 19, 2004 | 09:07 AM
Chunger's Avatar
My other car is a Hybrid
If you LOOK, you will see that you will have to grind down another edge behind the removed bracket to get it flush.... If you need instructions... look at your grinder manual...
Old Oct 19, 2004 | 12:00 PM
TJ_Max's Avatar
Paradox Systems Vendor
yeah i had the same problem, def cut deeper or grind that piece back there down...get ure weather stripping ready, for the side of the corner lamp...i used one piece of the thick strip and it looks good
Old Oct 19, 2004 | 03:51 PM
Nick7455's Avatar
How did u guys secure your grille?
Old Oct 19, 2004 | 03:52 PM
nadir_s's Avatar
double sided tape/velcro (heavy duty) lined at the bottom of the grill to the bumper and zip tie at the top.
actually, i haven't zip tied ityet,... when i closed the hood, the grill was pretty secure in there. I'll zip it tonite most likely.
Old Oct 19, 2004 | 04:01 PM
TJ_Max's Avatar
yup i zip tied it through the holes on the radiator support to the zip ties holding my mesh grill in place....its very secure as is, so i left it
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
