TPS questions, auterra users step in
Old Oct 23, 2004 | 06:07 PM
96sleeper's Avatar
I had my palm pilot and auterra with me at the track to check my timing and a few other things. I was viewing the throttle position sensor (TPS), and I have a few questions.
I have a 2001 pathfinder throttle body with the 2001 TPS from the pathfinder. At WOT, it only gets up to 91.4% open. I thought that it could not be good, so I tried to adjust it to reach 100% at WOT, even though I correctly set it up with feeler gauges according to the haynes manual. When I rotate it to read more than 91.4%, it stays above 0% when the throttle is closed, and I thought that can't be good either. So is my range from 0%-91.4% okay, or do I need to try a different TPS?
Can anyone else with an auterra or similar verify TPS % ? Thanks.
Old Oct 23, 2004 | 09:15 PM
DAVE Sz's Avatar
Hooooooonda.....
It's fine. If I recall correctly WOT starts at 88% or something around there. If you're getting ~4V from the TPS at WOT you're fine.
Roymg
Sep 3, 2018 05:10 AM
schmellyfart
Sep 25, 2015 04:47 PM
mikekay
Aug 10, 2015 12:52 PM
