Tranny nises !!!!
Old Oct 25, 2004 | 01:26 PM
Abimax95's Avatar
Tranny nises !!!!
Hi there guys last week my T/O bearing started to make noise I replace the clutch and flywheel and all that... than last week I was driving with my girls and I had to stop on trafic as I try to put it on first gear it would not go I try second it would not so I put it on 3rd it took it but after a couple of feet I smell burning cluth latter on it took first gear and second than this sunday the same thing but I put all gears than on first than it took it ..Is my tranny bad or is it beacause of the T/O bearing ?????
Old Oct 25, 2004 | 01:46 PM
Phaeton's Avatar
Is your tranny making noises still? If so, the TOB should probably set itself after a 100 miles or so and the noise should go away. If it doesn't go away, there is a chance that the TOB could have been defective in the new clutch. Did you go OEM or aftermarket clutch (aftermarket as in the kind of clutches you can buy for $100 cheaper at a NAPA or something)? Hope there is a warranty with what you got and the company would replace it for you (they might give you a hassle if you return it that it's oil soaked so you may have to fight for another clutch at no cost).
Check your clutch fluid resevoir. Might be low on fluid or might not have any at all. You might be smelling burning brake fluid that's leaking from your clutch resevoir or somewhere along the line. Are you getting decent pressure on your clutch pedal?
Old Oct 26, 2004 | 07:43 AM
Abimax95's Avatar
Tranny noises !!!
Hi there P I got the TOB at a Nissan dealer my clutch is Centerforce Dual Friction as of the reservour it goes down cause my s/c is leaking a little so you think the noise will go away !!! and is not my tranny goin bad cause sometimes it doesn't want to take first or second gear this only has happen twice .....thanks for the info !!!!
Old Oct 26, 2004 | 08:52 AM
Phaeton's Avatar
There's a chance the sound would go away IF the TOB sets itself properly. It COULD set itself after about 100 miles or so of driving. If it doesn't go away, you could have a defective TOB - which the odds are against it, but it is possible. I'm assuming that your the new TOB was installed when you got the new clutch kit. If the sound is happening with both the old TOB + old clutch and the new TOB + new clutch, you might be in a bit of tranny trouble...
Any other symptoms besides the noise? Power doesn't seem to be right at the certain RPMs? BTW - does the noise that you are hearing only occur when you are off the clutch and sounds like metal rolling around with a sort of rhythm?
MaxStock
Dec 5, 2016 05:19 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
