hood springsisnt holding up the hood anymore....what to do?
Old Oct 25, 2004 | 05:14 PM
Jonny98max's Avatar
i was looking at my engine bay the other day and i realized that my hood springs arnt holding up my hood anymore....my hood gradually closes by itself.....what can i do....where is the best place to buy some new ones?
prices?
Old Oct 25, 2004 | 05:43 PM
MDeezy's Avatar
you can get new struts from advanced auto parts ~$40 for 2, will hold that hood up for you.
Old Oct 25, 2004 | 08:06 PM
sterlingmaxima's Avatar
i did this last week autozone. Same price really bothered me
Old Oct 25, 2004 | 08:10 PM
amulla01's Avatar
man i got same thing this is so annoying... honda was smart they put a holding stick
anyways because of this i cracked my plastic where the wiper is(cracked the area around the wiper base ) cause i put screw driver to hold the hood...
Old Oct 25, 2004 | 09:43 PM
tomservo291's Avatar
one day i was working on my car and there was this little piece of wood about 1" thick by about 3x3" ... i was like, sweet just what i need.
now whenever I open the hood I wrap it in a rag and wedge it in the corner where the hinges are, works great
Old Oct 25, 2004 | 09:46 PM
97SEMAXI's Avatar
hahahahaha, you and every other 4th gen has or had this problem............im a huge fan of the vice grips
Old Oct 25, 2004 | 11:44 PM
Phaeton's Avatar
Vice grips - most definitely. Best $10 bucks I've spent to fix this problem.
Old Oct 26, 2004 | 12:10 AM
mm347's Avatar
But mine started leaking...so I need some replacements.
How is the quality of the AutoZone/Advanced Auto Parts struts?
Old Oct 26, 2004 | 12:16 AM
Wisky97SE's Avatar
I say go to a junkyard and get some off a late model Maxima w/ low miles. OEM quality + cheap junkyard price = teh win.
Old Oct 26, 2004 | 12:36 AM
happyricefob's Avatar
V^___^V
i'm using 1992 integra type-r rear tie bar as my hood support for free
Old Oct 27, 2004 | 05:00 PM
the auto zone ones are not the bad and i would say very easy to install they are a little different becuase the screw must be placed in the ball joint as opposed to allready having the screw in the joint like the oem's.
Old Oct 29, 2004 | 05:00 AM
mm347's Avatar
How long have you had the AutoZone struts on Max?
Old Oct 29, 2004 | 05:52 AM
Iron Scimitar's Avatar
Tha Snatcher
I'm using a baseball bat
Old Oct 29, 2004 | 06:00 AM
Brudaddy's Avatar
In honor of the Sox? ha ha
Old Oct 29, 2004 | 08:21 AM
MrDicks95SE's Avatar
Offset Is Everything.
hahah im using a baseball bat too. aluminum. its half protection and half for holding up my hood.
Old Oct 29, 2004 | 08:24 AM
has anyone had the hood fall on your head when you were working on the engine? heh it hurts real bad. stupid hoodstruts.
Tha Snatcher
nah, it's 1/2 protection and half holdin up the hood like ^^ just said. Mine is wooden tho.
Old Oct 29, 2004 | 08:27 AM
PTownMax's Avatar
I still miss the max
i use this metal pole... think it was a flagpole, but it works
Old Oct 29, 2004 | 09:34 AM
A32Matt's Avatar
i just cut a nice piece of 2x2 and use it for a prop since my hoodstrut started leaking pink crap out of it and didn't hold up my hood. got enough weight in it that i don't need a baseball bat anymore.
Old Oct 29, 2004 | 09:57 AM
Jepht20's Avatar
Custom User Title...
i got a pair of strong arms for 9.99 through my father's work which have lasted for over a year. the only time they're not so good is when it's cold out and high winds. i had it fall on my once last week while doing a coolant flush so i used a piece of wood just in case.
some people have recomended these and i want to get one. others speculated it might ruin the strut, but if your struts are dead anyways, i wouldn't worry about it. i doubt it would even damage a good strut unless you put it on too tight. http://www.thetoolwarehouse.net/shop/LIS-44870.html
some people also use vice grips for safety measures.
you could also just get a hood prop from a junkyard and custom do it in your car.
just a few ideas for you...goodluck
Old Oct 29, 2004 | 10:29 AM
drunkenmunky23's Avatar
does anyone know whether the struts of a 2k2 hood would fit my 4th gen (99)?
Old Oct 29, 2004 | 10:46 AM
Pappa Grande's Avatar
You may be lucky like me. It turned out that only one of my hood struts was bad. So I'm out $20 no big deal.
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
howardis
Dec 11, 2019 06:10 PM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
