What piece is missing from this VQ? *pix*
Old Oct 27, 2004 | 01:57 PM
Colossus's Avatar
I have a 1997 I30.... this part is attached to the air intake:
http://s87266458.onlinehome.us/album...0074.sized.jpg
My mom just bought a 1996 I30 and it is missing the part, but the car runs perfect, here is a pic:
http://s87266458.onlinehome.us/album...0075.sized.jpg
... Was this part added for 1997 or is she missing something off the '96?
Old Oct 27, 2004 | 02:12 PM
njmodi's Avatar
Do I get a tax break?
I believe thats called a boost sensor - don't know much more about it...
Old Oct 27, 2004 | 02:15 PM
Dubbya's Avatar
VK56 Inside
Thats what I thought it was too. I have been told its an important piece?
Dub
Old Oct 27, 2004 | 02:19 PM
PRPmax's Avatar
I believe the sensor detects the total amount of nitrogen oxide. Don't quote me on that.
Old Oct 27, 2004 | 02:21 PM
NmexMAX's Avatar
dot dot dot ...
I've seen it on 96+ not 95.
Old Oct 27, 2004 | 03:16 PM
RA030726's Avatar
I'm nutty for Nissans
yes that is the boost sensor, its probably hiding below some where. if it aint broke dont fix it.
Old Oct 27, 2004 | 04:31 PM
kcryan's Avatar
my 98 has a sensor that would apear to check to see if the hoods open but it had no wires goin to it?
Old Oct 27, 2004 | 06:47 PM
NYC_Maxima97's Avatar
That's the boost sensor for sure, but I'n not exactly sure what it does either, i'm sure you if you do a search you can find something. I remember reading about it.
Old Oct 27, 2004 | 06:53 PM
meccanoble's Avatar
Sports Button FTW
absolute pressure sensor i believe (if damaged u get code 08 03). I dont think it hurts performance but car looks at it for some special testing. Whatever code 08 03 gives u, thats the sensor, i know that for sure cause i replaced that and code went away.
Old Oct 27, 2004 | 07:11 PM
matty's Avatar
It does NOTHING but meter air coming from the front of the car...Mine is laying in my engine bay doing nothing
-matt
Old Oct 27, 2004 | 07:14 PM
njmodi's Avatar
Originally Posted by slammed95
Boost sensor measures atmospheric pressure to adjust the fuel mixture for air density/elevation changes.
I think you mean the MAP/BARO - but I don't think the particular part here is the MAP - it is marked on my car as a boost sensor. The MAP sensor is along the intake path.
Old Oct 27, 2004 | 07:15 PM
I30tMikeD's Avatar
96 I30's don't have them
Old Oct 27, 2004 | 07:18 PM
TheMax95's Avatar
Exactly as said before, it measures atmospheric pressure. The car runs perfectly normal with or with out it. I have been driving my car for the past 3 weeks without this boost sensor in the car. My brother accidently broke the little nipple sticking out of it so I just took it out. I will glue it back together sometime and put it back in.
-Paul
96 SE 5speed i/y
2.28
14.762
93.8
Old Oct 27, 2004 | 09:18 PM
bigleman's Avatar
Advocatus Diaboli
i read somewhere (the intake install in Shop Talk) that b/c the stock airbox has the intake that is aimed forward when at high speeds air is forced into the intake and it measures that increase in preasure.
REDinLV
Aug 15, 2024 12:30 AM
jmlee44
Oct 2, 2022 02:13 PM
zmcneely13
Sep 26, 2015 02:26 PM
rbaker100
Sep 25, 2015 07:52 PM
