Hayden Trans cooler.
Old Oct 28, 2004 | 06:03 PM
Maxima Mike
Okay, just got mine yesterday. Is it hard to install? Is there a write up anywhere? I'm a n00b when it comes to installing stuff, so is this going to be easy?
Old Oct 28, 2004 | 06:07 PM
MaximaSE96's Avatar
Maxima Owner
did it to mine in an hour....there is a write up i think its in shop talk on maxima.org main page https://maxima.org/modules.php?name=TMC
Old Oct 28, 2004 | 06:15 PM
Maxima Mike
Sweet, thanks.
Old Oct 29, 2004 | 07:55 AM
Dubbya's Avatar
VK56 Inside
Its way easy. Make sure to get some bigger hose to cover the smaller hose in places where it might rub against metal. The last thing you want is one of those hoses going out on you.
Old Oct 29, 2004 | 09:39 AM
MaximaSE96's Avatar
Maxima Owner
word......get xtra hose too
Old Oct 29, 2004 | 10:00 AM
DAVE Sz's Avatar
Hooooooonda.....
Does it get cold in the winter in SLC? Yeah, I thought so. Throw out that hayden and get a b&m cooler. They have a bypass hose for the winter so you're not cooling the trans when it's cold outside.
Old Oct 29, 2004 | 11:48 AM
THT's Avatar
THT
Throbbing member
Would cooling the tranny fluid during a midwest winter be bad for the transmission? Or is the B&M bypass just a marketing gimmick?
~THT
Old Oct 29, 2004 | 11:56 AM
DAVE Sz's Avatar
Hooooooonda.....
Makes sense not to cool it in the winter.
Old Oct 29, 2004 | 11:58 AM
Maxima Mike
I asked the guy at mobiletek and he said it'd be fine to run the hayden cooler. I dunno, I'll look into that B&M cooler.
Old Oct 29, 2004 | 12:07 PM
MDeezy's Avatar
this may seem like a stupid question but I'll ask anyway.
The write up is basically the same for all tranny coolers right? I was looking before for the specific kind of tranny cooler used in the write up but found one like it but not exactly like it, and just wanted to make sure its pretty much all the same thing.
thanks
Old Oct 29, 2004 | 12:47 PM
Xugg's Avatar
i really dont think a tranny cooler would harm anything unless you're redlining it while it's still warming up....
Old Oct 29, 2004 | 01:11 PM
Nazca's Avatar
I had a hard time finding transmission cooler hose. Called all around the big boys, but no luck. I ended finding a prepacked 3' section at NAPA, but the diameter was slightly smaller than the included hose. Just had to dip the end in boiling water for a min to soften it up, then it slid easily over the nipple on the cooler.
I can't say how much of a difference the cooler made, because shortly before installing I dropped the trans pan, replaced the filter, flushed the trans, and replaced fluid with synthetic ATF. But I will say after the flush and installing the cooler, the car shifts much, much smoother and I dont get that hard down shift into 1st anymore.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
pears
Sep 18, 2015 05:25 AM
