posted about 5 times, yet no solid answer..
I'm doing the LED's in my auto climate control. is it a problem to just solder on a resistor to the led and solder that directly onto the board? or do I have to follow the instructions on the 'how-to' using wires and connecting to a 12V source? I'm wondering if there were problems soldering to the board directly, thats why the how-to was done connected to a separate 12V source. i don't want to mess up the climate control because I've already messed up other buttons. can someone give me a clear answer?
leds per the 'how-to' directions?
leds w/ resistor soldered directly to the board?
thanks, Dave.
thanks, Dave.
YES, you can definitely solder directly to the board. I did it and it worked great.
Tips:
You will see tiny parallel lines that are the contacts to the bulbs that twist out. It's not easy to solder onto these as is. What I did was cut a tiny piece of wire to go perpendicular to them and solder that in place. This will give you a very nice solid place to solder the LED with resistor to.
When looking at the BACK of the board... ( the flat edge to the left and the slanted edge to the right ) the contacts on the right of ALL 3 twist out bulbs is positive, the other is negative. Make sure to put the LED in correctly oriented.
Good luck.
Tips:
Good luck.
The How-to I have has it the way you want to do it http://www.petah.org/maxima/climate.htm. Can you give me a link to your how-to? More info is never a bad thing.
why would you put leds, plasmaglow sells replacement cluster bulbs including the auto climate control so you can change the color of the display without modifying anything. I dont know if thats what you were going to do,
if you need to find a plasmaglow distrub. www.autoaccessorystore.com has them
i finished leds in the climate control. Even though I sanded the leds down, still some hotspots, but overall, at least i can see which button is which in the dark. looks nice with the hazard/defrost led swap.
direct replacement bulbs? if they're not 8-10 bucks a pop like at nissan, show me where.
MaximaDrvr
08-19-2015 08:20 PM
