CEL Advice (0705) (0903)
Old Oct 31, 2004 | 10:14 AM
Nismotic's Avatar
Always sunny in philly
Stickies indicated that I'm throwing 0705 (Evaporative Emission Control System) and 0903 (Evaporative Emission (EVAP) Canister Vent Control Valve or its associated electric circuit.)
Has anyone had this code corrected it? i want to try to take care of it first before taking it to the shop. What should I be looking for in order to recify the problem?
Old Oct 31, 2004 | 10:38 AM
njmaxseltd's Avatar
The vent valve & canister is located behind the left rear wheel and is subject to road debri, which usually renders it clogged. You can take the valve out, clean it up with some WD-40, get it all cleaned out and working then reinstall it.
That usually solves the problem.
Old Oct 31, 2004 | 11:00 AM
Nismotic's Avatar
Is it a small canister like part? I'll take a look at it today. thanks njmaxseltd-
anyone else have experience w/this?
Old Nov 1, 2004 | 10:21 AM
wharfrat's Avatar
I also had that problem. A year ago I removed the valve ( 4 bolts) and wiggled the valve out. I tried fixing the original, but couldn't really get it fully loose. Re installed it had the CEL 2 days later. Ordered the new part, $35 or so, and haven't had a problem since. I didn't notice any adverse effects other than having to see the CEL inside, maybe decresed mileage, but not drastic. It's an easy fix. I had moisture in mine that rusted the valve open.
Old Nov 1, 2004 | 08:25 PM
Nismotic's Avatar
what part is it again? i noticed a decrease in mileage. there was a fuse loose in my engine bay so i popped it back in and praying that the CEL wont trip
Old Jan 6, 2005 | 10:24 AM
randy021186's Avatar
Hey man guess wat i got the same problem....i happeded when i put injector cleaner in the tank..........i started with 0705 first then 0705/0903 so i did was drive in a big puddle of water on the leftside rear last night ( did this because it can remove dirt) and then today i got the code 0505 which i presume it mean a problem has been fixed and i was getting bad milage for my gas..i just recently did a post name 0505 read i let me know how u fixed ur problem
Old Jan 6, 2005 | 10:53 AM
SUM41GIRLIE's Avatar
I've had 0903 for almost 2 years now had 3 shops including Nissan look at it. I've had a whole new evap system put in and also a smoke test done to see if there were leaks, nothing! Then they said my ecu is causing a false code..Had that replaced...Code came back....So if anyone has had the same or similar problem where they cant get rid of the code and then finally found the problem, please!!!! let me know!!!!!!!
Old Jan 6, 2005 | 01:10 PM
KCMaxima98's Avatar
On my '98 I had 07 04 and 02 15 codes which related to the EVAP system. If you reset the ECU the CEL may not come back on for up to a week but trust me it will come back. I have heard stories of people trying to diagnose and fix their own EVAP problems just to have the CEL come back on later.
I took mine to the dealer and found out it needed a EVAP system vent control valve. Parts and labor at the stealership was only 128.00. I would recommend taking it to a dealer for EVAP problems if you want it fixed for good. Also, this part is known to go out on our maxes. If you look up a 4th gen maxima on the MSN auto page it states that it is a common failure on our cars.
Old Jan 7, 2005 | 07:56 AM
Yeah but I didnt do the evap system myself, I went to Nissan and they are the ones who did the smoke test, and replaced the valve, canister and ect and the light still came back on. Nissan could not figure out why its still on because they said they checked every possible thing to trigger the code for the evap.
Old Jan 7, 2005 | 05:09 PM
kickyoazzz's Avatar
did you guys notice any sluggishness or just poor gas mileage from the code?
Old Aug 9, 2005 | 11:59 PM
l3ftonm3's Avatar
well im pulling these codes now and google searched the org and lead me to this thread. I went behind the left wheel well and there are 3 parts underneath, the white piece with the one hose going down into it and then the 2 hoses going into the huge box.(what is that box anyways?) also the canister which has the foam filter inside it. I looked at all 3 of them the box you cant take apart, the 2 other pieces werent dirty at all. I cleaned the electrical connections put it together reset the ecu and bam next day same code is back. So any ideas? The only part I could see not working would be either the huge box or the white circular piece. Am I even looking at the right stuff to diagnose this problem? Thanks
Old Aug 10, 2005 | 12:10 AM
MaximaSpd85's Avatar
i have the same codes, but my vcv couldnt come out, the bolts just kept rotating..the vcv is the one with two bolts, one tube and one connector (i think!) my bolts wouldnt come out so i just left it alone, i've read that 0705 does not affect performance as it is just a self-diagnosis, but dont know bout the 0903!! i hate that orange light in my dash! and this all popped up a few minutes after i changed my o2 sensor!!
Old Aug 10, 2005 | 08:28 AM
l3ftonm3's Avatar
bump, any other people with any pointers. I have to get my car inspected and it wont pass if the light is on and the problem being emissions related dosnt help either.
Is the vcv part of the box underneath behind the wheel well. I tried unscrewing those too and they would just spin and not budge.
Old Aug 10, 2005 | 08:36 AM
cttiger's Avatar
I have the exact same codes after changing my O2 sensor as well... Anyone know if they could be related in any possible way? Seems strange...
Old Aug 11, 2005 | 09:20 AM
CalsonicSE's Avatar
The reason why the small bolts that attach the VCV to the canister are spinning is because the threaded metal sleeves that the bolts screw into are molded into the plastic canister, and now after many years the plastic area around the metal sleeves is broken or whatever and so the metal sleeve is spinning with the bolt as you try to unscrew it. I hope this makes sense.
How do I know this? I know this because I recently experienced the same problem. Fortunately, I was in the process of replacing my old canister, and all I was worried about was getting the old VCV off to attach to my new canister. One of the bolts that attach the VCV came off pretty easily, but the other one just spun in place. So, I took a hand saw, hacked open the old canister, and discovered the problem as descibed above. After cutting away enough of the plastic that surrounded the metal sleeve inside the canister, I used channel locks to hold the sleeve in place (pliers weren't strong enough), and that allowed me to unscrew the the bolt.
Unfortunately, I really can't see how someone can take off these "stripped" bolts without opening up the charcoal canister.
Old Aug 11, 2005 | 11:48 AM
l3ftonm3's Avatar
well if thats the case looks like I need to get to work and just replace the whole canister or chop away at it.
Old Aug 11, 2005 | 11:59 AM
CalsonicSE's Avatar
Well, if you don't wanna chop up the canister, I guess you can find someway to cut the troublesome bolt at the spot in between where the VCV and canister meet. Then you can easily unscrew out the top half of the bolt. BUT then again, the bottom half of the bolt will still be screwed into the metal sleeve in the canister. =P
Old Aug 11, 2005 | 05:05 PM
l3ftonm3's Avatar
Anyone know the part # for the canister and the control valve? And how much they may run cost from nissan?
Old Aug 11, 2005 | 10:05 PM
l3ftonm3's Avatar
ahh i read 35 from above, coo nissan tomorrow morning
Old Aug 12, 2005 | 08:59 AM
Fork's Avatar
Maximaler Experte
Mine was caused by the valve that opens and closes the canister to stick. Some WD40 later, it's working just fine and the code is gone.
Old Dec 2, 2005 | 12:19 PM
bigx323's Avatar
BUMP... exact same problem, ive had the whole system cleaned, new ecu and evap system... code is still there
anyone found a way to fix this yet?
the stickie mentions something about 10amp fuse #58, but my fuses only go up to #40...
would really appreciate some help
Old Dec 2, 2005 | 09:37 PM
p00tan6's Avatar
replace the carbon/charcoal cannister and the vent control valve on the cannister. I had the same exact 2 codes.
Mahmuth
Aug 16, 2024 08:23 PM
jmlee44
Oct 2, 2022 02:13 PM
gigabyte
Jan 6, 2017 06:05 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
