fuel filter replacement
Old Oct 31, 2004 | 01:36 PM
SmackDown85
alright guys ive never replace the fuel filter in my max, i got a 96
can someone give me an idea of where it is and how to replace it? also, what are some signs that i need to change it and/or by looking at it?
also what kind should i buy?
thanks guys
Old Oct 31, 2004 | 01:49 PM
A Flood99's Avatar
watch out you might get flamed....read the stickies, you should probably replace the filter as soon as you can
you can go with the 300Z filter or a new OEM one.....that's the choice i'm debating right now....i have a question though, anyone with the 300Z filter have you ever had a problem with your fuel pump due to a bigger filter? I am just wondering if i should use that filter(even if it does filter better) since its not designed for our cars or engines
Old Oct 31, 2004 | 02:11 PM
aznsap's Avatar
i have the 300zx filter in my car and have had no problems.
Old Oct 31, 2004 | 02:24 PM
kcryan's Avatar
it is designed for our engines isnt it? didnt the 300zx's have the VQ30?
Old Oct 31, 2004 | 02:26 PM
dmBK's Avatar
How 'bout them cliffs?
300zx had a VG
Old Oct 31, 2004 | 03:00 PM
ny96max's Avatar
go to nissan and buy a 1996 300z fuel filter... $15-20 i think?
Ant
Old Oct 31, 2004 | 06:47 PM
my99maxisnice's Avatar
It doesn't filter any better, it just lasts longer. And when I changed mine, I used OEM, and it was a tight fit, I don't know how a bigger filter could've fit.
Old Oct 31, 2004 | 09:02 PM
SmackDown85
ok sounds good guys, BUT.....
how do i install it? i dont know where the fuel filter is located in my car..
do you guys know of a site w/ a write-up on how to do it? i change my oil all the time, but never the fuel filter..sorry for the newb questions
also what kind of negative effects can an old fuel filter have on your car?
Old Nov 1, 2004 | 01:37 PM
a write up is in the Stickies somewhere...go breeze through there.
Old Nov 1, 2004 | 03:04 PM
Thorby's Avatar
I am too lazy to explain, but here goes...
1. Find the fuse for the fuel pump. Can't help you on this one so go look for a manual that tells you the fuse numbers at least. (Wait, that makes this reply pointless because that manual will also tell you how to replace this thing....). Anyhow.
2. Turn on the car with the fuse ON. Then, take out the fuse. See how the engine dies after a few seconds. This will drop the fuel pressure in the system, which is very important if you want to take apart anything in the fuel system.
3. Find the filter, which should be right in front of the firewall in front of the driver (on the engine compartment). It shoud be a cilindrical thing that has an IN house and another OUT house on the other end of it. Mine is silverish aluminum.
4. Loosen the clips that hold the hoses with a screwdriver and pull out the old filter.
5. When you install the new filter, make sure to follow the instructions in the box to put it in the right direction (don't put it backwards).
6. Be very careful with the hoses, don't be like my asswipe exmechanic who damaged a hose which let fuel seep out. (Need I say how dangerous a fuel leak is?)
7. If you don't have hands and arms skinny enough to reach, carefully remove, as long as you are confident, what you need to remove to access the fuel filter. I think the air filter housing needs to be removed.
There is not much to it. Just to be careful when removing stuff to be able to get your hands on the filter. In case you still havent found it: it is real close to the master brake cilinder.
A Haynes manual is real helpful for this kind of stuff, but... it is not that complicated. Good luck.
Old Nov 1, 2004 | 03:57 PM
VIP Maxima
http://forums.maxima.org/showthread.php?t=260358
Old Nov 1, 2004 | 04:25 PM
Maxima_NRH's Avatar
Might be a dumb question here, but any tips on loosening the hose from the filter? My hose is LOCKED on that filter and I'm worried I will need to cut the thing out. Suggestions?
Thanks.
Old Nov 1, 2004 | 06:57 PM
Wrightsfd's Avatar
Don't cut it, get back in the car and crank the engine for 15 seconds 3 times. Then crank it some more. You need to get ALL the pressure out of the fuel line. The hose will come off. Keep cranking the engine with the fuel pump fuse disconnected.
Old Nov 2, 2004 | 12:43 AM
miked15's Avatar
how do you crank the engine?
Old Nov 2, 2004 | 05:34 AM
dallas0593's Avatar
miked15 how do you crank the engine?
Are you kidding? He means turn the key and let the engine turn over acouple times!
Old Nov 2, 2004 | 06:54 AM
Maxima_NRH's Avatar
Ok thanks for the tip! I will try that this evening.
00MAXI
Sep 2, 2015 10:23 AM
305head
Aug 26, 2015 09:03 PM
homewrecker
Aug 24, 2015 08:56 PM
kirkhilles
Aug 8, 2015 10:53 AM
maxima297
Aug 3, 2015 12:50 PM
