'99 revs high on startup
Old Nov 1, 2004 | 01:03 AM
dmitri47's Avatar
it seems to rev high for a few minutes when i first start it up. usually between 1400-1700rpm
seemed to only start doing it recently (ive had the car a few months), but then again, it just started getting cold, is this just the car warming itself up?
Old Nov 1, 2004 | 02:15 AM
Nick7455's Avatar
I've noticed mine does this when it gets cold....so that might be it
Old Nov 1, 2004 | 04:39 AM
Phatmax98's Avatar
clean your throttle body..it may help
Old Nov 1, 2004 | 07:24 AM
f550maranello2's Avatar
yea i got the same problem on my 97 its only for a few minutes though, it does not matter what kinda weather it is .
Old Nov 1, 2004 | 08:13 AM
Maximasevspec's Avatar
thats what i did it, helped a lil bit
Old Nov 1, 2004 | 09:47 AM
tedo007's Avatar
faster than you think
thats normal.... if you engine is cold every car does that to get the engine warm up
Old Nov 1, 2004 | 10:03 AM
I30tMikeD's Avatar
hahahahha.....you guys kill me. Your car is doing exactly what it is supposed to do, don't worry about it.
Old Nov 1, 2004 | 11:20 AM
Seximus Maximus's Avatar
Normal. Just a cold start is all.
Old Nov 1, 2004 | 11:02 PM
dmitri47's Avatar
heh, i used to drive a '66 malibu, im not used to a car having a brain. it just does things sometimes that worries me. i guess my car is just smarter than me
anyways, thanks for the help
Old Nov 2, 2004 | 05:10 AM
njmaxseltd's Avatar
You can adjust the cold start idle speed.
On the lower linkage down below the TB, slightly to the left there is a plunger that comes out of the TB. Thats the cold idle plunger. It moves in and out, pushing against the lower linkage, opening the TB plate slightly for a cold start. There is a screw on that linkage that will adjust the amount the throttle is held open when the engine is cold. I have mine set to approx. a 1500 RPM start up. If you look closely on the first cam plate, there is a scribe mark on it. That mark lines up with another mark on the link it sits on. If you line those two marks up on a cold morning, you should have a cold start of approx 1500 RPM's, which quickly drops to around 1250 as your engine warms up.
The Haynes manual describes that procedure.
Old Nov 2, 2004 | 05:57 AM
chenzarino's Avatar
OMG! My car works properly! what do I do?
maxinout93
Oct 31, 2015 02:04 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
