ECU Code 0705
I am 90% sure that their is a Technical Service Bulletin about this..
http://www.alldata.com/recalls/
go check the year of your car..
if so have the dealer fix it for free
Originally posted by shuefu
EVAP Control System, what does this do?
-Thanks
-Thanks
1998 Nissan Maxima SE
Here's the info I found from that site....
http://www.alldata.com/TSB/41/98416289.html
Doesn't really mention the EVAP Control System.
Re: 1998 Nissan Maxima SE
damn i was hoping you had a 96
http://www.alldata.com/TSB/41/96411757.html
well i will shut up now and let Daniel give you the real answer
Jackpot
-Thanks
-Thanks
This malfunction is detected when the EVAP control system has a leak or the EVAP control system does not operate properly. (EVAP = EVAPorative emissions.)
Possible causes include...
- incorrect fuel tank vacuum relief valve
- incorrect fuel filler cap
- fuel filler cap vent remains open or fails to close
- foreign matter caught in fuel filler cap
- a leak in the line between the intake manifold and the
EVAP Canister Vacuum Control Valve
- foreign matter caught in the EVAP CVCV
- leaks in the EVAP canister or fuel tank
- leaks in the EVAP purge line (pipe and rubber tube)
- EVAP purge line rubber tube bent
- blocked or bent rubber tube to EVAP control system pressure sensor
- loose or disconnected rubber tube
- EVAP CVCV and circuit
- EVAP Canister Purge Volume Control Solenoid Valve and circuit
- absolute pressure sensor
- tank fuel temperature sensor
- MAP/BARO switch solenoid valve and circuit
- blocked or bent rubber tube to MAP/BARO switch solenoid valve
- O-ring of EVAP CVCV is missing or damaged
- water separator
- EVAP canister saturated with water
- EVAP control system pressure sensor
- refueling EVAP vapor cut valve
- ORVR system leaks
This is a "jackpot" DTC. It points to so many things you don't know what to check. It is often combined with another DTC which is more specific and therefore more helpful.
Re: Jackpot
Wow, didn't know it was gonna be that big of a problem. I guess it would be best if I had Nissan check it out? I just had my alternator replaced, would that cause it?
I also reset the Check Engine Soon light so now it's not there anymore, would it lid up again? Should I wait?
-Thanks.
-Thanks.
Be patient
-Thanks.
-Thanks.
Re: Be patient
That's exactly what I did. I reset it the light, now it's gone, I wasn't sure if it'll come back or what.
I guess now I'll just drive it like normal and see what happens. When I got my alternator replaced last week, they said my engine is in excellent condition. Let's see what happens.
Re: Re: Be patient
Hey...I got this code couple weeks ago. Was also accompanied by a code 0705 which is EVAP Canister Vent Control Valve. Bought one from courtesy nissan for $45. Hope you get another code to narrow it down, or maybe it fixed itself?
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
