How's your manual tranny holding up?
Old Nov 2, 2004 | 04:06 PM
Fekz's Avatar
Just bought my 96 black/black SE, manual, loaded, ect. 96k mi, transmission shifts strong, no jerking no problems at all. How long is the life expectancy of the manual tranny?
Old Nov 2, 2004 | 04:17 PM
mansurxk's Avatar
on the 95-97 its less because of the differential bearing problem, of teh ones that fail, majority failed around 60k, others fail in the low 100, varies case to case, mine has 130k, im the 3rd owner, to my knowledge, and the 2nd owners knowledge, ther ewas never a differential bearing failure in my car. i have a 95
Old Nov 2, 2004 | 04:20 PM
Half_Lunatic's Avatar
tranny is good except for the 2nd gear syncro problem, if I shift too fast from first to second I get a nice grind... btw I have a '96 se.
Old Nov 2, 2004 | 04:34 PM
Maximus_95's Avatar
i have a 97 se and im on the 3rd tranny. but i was boosted for a while.
Old Nov 2, 2004 | 04:58 PM
BigLou93SE's Avatar
I have a '96 SE, and assume I had the diffy bearing problem...original (I think) tranny replaced at 133k, had 3-4 more trannies from 98-99's put in to find one that worked. I guess its the luck of the draw, I don't know.
Old Nov 2, 2004 | 06:18 PM
ChristheNite
at 130K my stock 1996 $hit the bed, just got a 2k and it has a busted 2nd gear syncro - so I have the pleasure of uninstalling it again (even though the di(k that sold it to me said it was fine...)
Old Nov 3, 2004 | 05:50 AM
Igobuk's Avatar
I have a 97 SE manual with 106,000 miles... no problems and still the stock clutch.
Old Nov 3, 2004 | 06:09 AM
Batxel's Avatar
blah
When I first bought my max it was extremly hard to shift into 4th gear at high rpms(probably why it was sold). I switched the fluid (redline mt 90) and seems to be alright now. Two weeks ago it was extremely hard to shift but it only happened one day. The other day my clutch pedal really soft. I hope this is all slave cylinder issues.
bought it at 120,028 ~ 5/14/04
fluid change 120,760 ~ 6/01/04
today 129,140 ~ 11/03/04
it better make it to 300k !!!!
Old Nov 3, 2004 | 06:16 AM
SkoorbMax's Avatar
97 with 87k on original tranny and clutch. I've only had the car 10k miles. It's a bit touchy going into second when it's cold. Not "touchy", but you do have to beware of the synchros, and not throw it right into gear. Otherwise the tranny seems good.
Old Nov 3, 2004 | 06:56 AM
Wil's95SE's Avatar
我爱台湾
well I have a 95 SE w/118,500 miles on it and the first gear synchro is shot. Will be replacing it this weekend with a 97 tranny. Hopefully won't encounter that problem again. Have a Exedy clutch that I put in around 100K miles. Bought the car when it had 88K miles on it.
Old Nov 3, 2004 | 07:08 AM
motocross416's Avatar
The tranny in my 95 went at around 100k. My dad has a 97 and the trans was replaced somewhere around 50k-70k miles. But that car was turboed for a while so that might have something to do with it.
Old Nov 3, 2004 | 08:17 AM
MDeezy's Avatar
96 SE, at 96K differntial bearing problem and a worn input shaft so that tranny had to throw in the gargage. At the time I didnt know about the dearing problem so I replaced my tranny with another 96 tranny, now I think I'm suffereing again.
Need a 2k1 tranny (hopefully VLSD)
Old Nov 3, 2004 | 11:46 AM
Fekz's Avatar
wow, Starting to sound like it would be better to buy an automatic.
Old Nov 3, 2004 | 01:15 PM
thisisausername's Avatar
the manual is fine unless you get diff bearing defect, and as far as I know not all trannys have it.
Car and Driver says the manual version of the car is much peppier though... read their review. They say that the automatic doesn't seem to have as much power (cuz it doesn't).
think about it this way... theres plenty of ppl trying to do auto to manual conversions but hardly anyone doing it the other way around.
Old Nov 3, 2004 | 01:43 PM
Zack342's Avatar
owned my 99 for about 16000 miles. tranny felt great still does althought i installed a B&M short shifter so i am sure the tranny dislikes this but whatever
Old Nov 3, 2004 | 02:11 PM
chuckie311's Avatar
i have 130 k on my tranny and it works fine.only thing i had to replace on my car so far is the clutch which went out at 116k from racing
Old Nov 3, 2004 | 02:13 PM
Supermax95's Avatar
99 5 speed, 97k stock clutch/tranni.
Old Nov 3, 2004 | 02:15 PM
mansurxk's Avatar
knock on wood, clutch is slipping, anyone know a place in NJ that does it cheap and reliable?
Old Nov 3, 2004 | 05:05 PM
PLUMMAXSE's Avatar
Hey MDeezy,
Did you try out your clutch the way I told you?
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
