Reseting the computer???
I just got a ws y-pipe and i need to reset the computer. does anyone know where i can because i heard there is a button somewhere by the pedals. also would takin out the battery also be reseting the computer??
go here ---> http://forums.maxima.org/showthread.php?t=104931.
Why do you reset your computer after a y-pipe, I never have...seems pointless, I have never seen hard proof that the ECU must "learn" new mods.
And if you do get codes, you probably will have problems...that's usually the rule of thumb...
is there any way to fix that , is it possible to move it or somethin out of the way because i've noticed that the whole exhaust is loose. i used to have a rattle noise before but that was also because it was loose and too close to , i think it was the gas tank, but it kept on hitting it whenever there were bumps on the road and i live in ny and theres always bumps on the road.
Mine doesnt vibrate all the time, only sometimes, it does get annoying, and mine also has a vibration sometimes during acceleration, but that's notoriuos for WS.
Mine doesn't make any noises at all when hitting bumps though. Check all your hangars and make sure the y-pipe flange is there to support your y, because if it's not you will have a bad flex section very soon.
would that battery thing do the trick tho? as for the rattle , i fixed it , i just moved it over a little bit thats all. but i dunno about that vibration while stopping cuz all of the passengers and the driver can feel it alot even if you have the music blasting lol, makes the car seem old.
Easiest way is to disconnect the battery, then press the brake pedal until the tail lights are out. This drains the capacitors that hold charge while your car sits without a battery (the capacitors keep the computer from 'forgetting' the timing and air/fuel maps). This resets the ECU. Resetting the ECU makes it 'forget' all of these maps. Then after a few revs through the gears the computer re-maps the timing and air/fuel ratio maps and you can benefit from the new lower-backpressure gained from the y-pipe. Otherwise it takes a long time and hard driving for the ECU to 'learn' that it has less backpressure and can fit more air into the cylinders since more air can come out. It only takes a couple of pulls to red-line to re-map them, so it save s a lot of time before the engine benefits. (It doesn't take miles if you get on the interstate and pull a few 4th gear to redline runs.)
Simple 4-stroke engine rules.
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
ballerchris510
Sep 23, 2015 08:46 PM
