Knock sensor Volt meter reading?
Old Nov 10, 2004 | 10:11 AM
Zipp028's Avatar
I remember comming accross certin numbers that would tell you if ur knock sensor is good. I cant remember the numbers nor the site or where u check it at.. if anyone has any idea what i am talking about let me know. thanks
Old Nov 10, 2004 | 10:16 AM
Stephen Max's Avatar
550 Kohms, measured from the KS pin to ground. Although there are two pins in the harness connector, only one will show the correct resistance if the KS is good. The other pin goes to the harness shield.
Old Nov 11, 2004 | 01:35 AM
ThurzNite's Avatar
my broken old one and new good one never showed correct voltage. Just a heads up.
Jae
ThurzNite's Avatar
oh yeah, correct voltage depends on the maker of the KS. There are 2 manufactures out there. pm me if u need more info.
Jae
Old Nov 11, 2004 | 05:49 AM
Zipp028's Avatar
what are the 2 diff voltages?
Old Nov 11, 2004 | 06:14 AM
Zipp028's Avatar
Do i check the voltage with the car on? what do i connect to?
Old Nov 11, 2004 | 06:16 AM
Jae
How are you measuring voltage? A knock sensor is a piezoelectric device, and will create a very transient voltage when it senses knock. It is not energized by the car's electrical system. The output amplitude depends on the severity of the knock. You would have to use an oscilloscope to capture the output.
Old Nov 11, 2004 | 10:21 AM
Zipp028's Avatar
i will measure the voltage with a volt meter..
Old Nov 11, 2004 | 10:33 AM
And you will get zero volts.
Old Nov 11, 2004 | 10:45 AM
njmodi's Avatar
Do I get a tax break?
Nevermind - I'm a dumba**
Old Nov 11, 2004 | 11:24 AM
ThurzNite's Avatar
Stephen, njmodi: are you saying the FSM is incorrect? It says if you measure ECU terminal 64 (white colored wire) and ground, it should read 2.0-3.0 volts when the engine is idling. If the ECU does not read volts, what does it read?
I made a mistake saying there's 2 readings for 2 ks manufacturers. There should only be 1 reading, regardless of which KS manufacturer you have.
Just to confirm the code you're getting Zipp028 do the following:
1) start engine and run at least 5 seconds at idle speed
2) turn ignition switch Off, wait at least 5 sec, and then turn ON
3) Check ecu for code (diagnostic test mode II)
The flow chart for KS goes like this
A) 1) turn the ignition to Off
2) Disconnect the ECM harness and knock sensor sub-harness
3) Check continuity between KS harness terminal 1 (left terminal if you're looking at the harness) and ECM terminal 64. It should be continuous. If not, check for shorts
B) 1) Check resistance between KS harness terminal 1 and engine ground. It should read 500-620 kohms. If ok, check harness for short. Otherwise, check the KS
C) 1) Check resistance between KS terminal 2 (left terminal if looking at the KS) and ground. It should be 500-620 kohms.
Jae
Old Nov 11, 2004 | 11:31 AM
njmodi's Avatar
I got it - I was a little as to how voltage was being measured with the KS disconnected... thanks!
Old Nov 11, 2004 | 11:33 AM
I didn't think we were talking about measuring volts at the ecu, but if that's what the FSM says then I stand corrected.
Old Nov 11, 2004 | 11:47 AM
ThurzNite's Avatar
The FSM could be wrong (this wouldn't be the 1st time). I'm curious from a learning standpoint and future reference, how do u check the condition of a KS?
Jae
Old Nov 11, 2004 | 12:03 PM
Jae
B and C in your post above is the way most people do it. However, I had a KS that would show the correct resistance sometimes, and then would show open circuit at other times. Evidently there was an internal connection that was intermittently flaky. After I replaced the KS it stopped giving the 0304 code and performance improved, so it was definitely a bad KS.
bbsitum
Sep 6, 2019 07:31 PM
220k+ A32
Sep 11, 2015 02:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
