Headers Installed Throwing Codes Need Help Plzz
Old Nov 11, 2004 | 12:01 PM
icedout's Avatar
INSTALLED OBX HEADERS ON MY MAX THROWING 2 CODES AT ME NEED SOME HELP.
CODES ARE 0807-EVAP CANISTER PURGE VALVE
1302- MAP/BARO SW SOLENOID VALVE
NEED SOME HELPS GUYS LET ME KNOW WHATS GOIN ON
Old Nov 11, 2004 | 12:03 PM
PTownMax's Avatar
I still miss the max
sorry man i don't know whats going on with it, but how was fitment? Did you have to pull engine to get them in there? I'd like to put mine in if i can get them to fit
Old Nov 11, 2004 | 12:05 PM
icedout's Avatar
they were a lil bit of a pain to get in the only thing i had to do was to cut the motor mounts to get them to fit in proper but once that was done everything else was smooth.
Old Nov 14, 2004 | 09:45 AM
PTownMax's Avatar
have you had any problems with the mounts breaking like "tilleys99"? Also what did you use to cut it with and is it evident what needs to be cut?
Old Nov 15, 2004 | 08:38 AM
icedout's Avatar
headers
nope had them in for a month now and no breakin so far so good.
but i had my machanic cut them and he just had to cut on each side of the mounts because the headers a a lil to big to fit but car runs great workin on gettin the rest of the obx cat back set up.
Old Nov 15, 2004 | 07:44 PM
PTownMax's Avatar
did you feel any good gains?
Old Nov 22, 2004 | 09:50 AM
icedout's Avatar
yepp
Old Nov 22, 2004 | 10:00 AM
NmexMAX's Avatar
dot dot dot ...
Dyno comparisons?
Old Nov 22, 2004 | 11:32 AM
Nismo3112's Avatar
Custom User Title
Originally Posted by icedout
yepp
Did you have a y-pipe before the install or no?
Old Nov 22, 2004 | 12:44 PM
SPiG's Avatar
SomePsychoGuy
http://forums.maxima.org/showthread.php?threadid=235667
0807 is the thing on top of the IM. If you removed your IM in order to take you rear exhaust manifold off, did you reconnect everything correctly? All of your vacuum hoses? That is probably both of your problems. I haven't been able to find much on the 1302. Hopefully something is just disconnected.
Old Nov 23, 2004 | 10:02 AM
icedout's Avatar
got the y pipe with the headers both obx workin on the obx car back got to get it dyno still gettin it dynoed after i get the obx cat.
Old Nov 23, 2004 | 10:37 AM
icedout's Avatar
thanks yea i think it has something to do with that one of my hoses is not connected,my friend told me anyways in my evap system so hopefully i can bring it to my friend and he can find the problem but the car sounds great and runn pretty damm good nice gains id say
VQ'ed
69
Aug 27, 2020 12:29 PM
Cotozic
Jun 28, 2017 08:01 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
homeyclaus
Sep 3, 2015 06:15 PM
doobadoo
Aug 15, 2015 06:43 PM
