** Car is not starting properly After (Clutch/flywheel) replacement.
Old Nov 11, 2004 | 04:44 PM
aphillips4u's Avatar
I'm not sure if this has any thing to do with my Clutch & flywheel replacement.
My stock clutch finally died. I found out I broke my clutch plate from old age and it chipped the crank sensor. I replaced the Clutch- (centerforce DF) & Flywheel- (Fidanza) and after installing the new clutch and flywheel the car would not start. It was flooded with gas from me trying to start it when it died no luck. We finally got it were it is idleing normal but when I tried to start the car it's not turning over like it use to. it starts after 2 tries
Can this be a timing issue with the new fidanza flywheel ?
My mechanic told me it turned over fine with the old flywheel. after changing the crank sensor. but he heard the broken clutch plate and turned the car off quick.
Old Nov 11, 2004 | 05:38 PM
njmaxseltd's Avatar
So you replaced the crank sensor and your still getting hard starts with the fidanza flywheel installed, but not the old OEM flywheel?
Old Nov 11, 2004 | 05:40 PM
vortechpower's Avatar
it is most likely the sensor ring on the stock flywheel that you have to put onto the new flywheel. So that means that you have to take everything back apart if you forgot this part. There is no spark....my brother just had this same thing happen to him on his 5th gen. I actually just got off the phone with my friend that did the install and this is what he told me.....
Old Nov 11, 2004 | 06:46 PM
The car does start now but it gives a hard start. It was flooded with gas from when it died on me.
Old Nov 11, 2004 | 06:52 PM
I'll be picking up the car tomarrow so I will update you guys..
the RPM's rev alot faster now hopfully i gain low end HP now.
Old Nov 14, 2004 | 06:42 PM
We did replace the sensor ring on the stock flywheel and put it on the new flywheel. I'm wondering if i should have changed the sensor ring also. We checked and there was no tooth missing on the sensor ring.
Old Nov 14, 2004 | 06:52 PM
Is it possible by shimming the starter would help the hard start problem?
I took the car to advance auto and they tested the battery and the starter there both fine. @ this point i'm not sure what's the problem.
Lakersallday24
Jun 16, 2019 01:35 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
DayHeyZeus
Garage and Workshop
Aug 16, 2015 12:29 AM
BobMax
Aug 15, 2015 12:35 PM
halfpol
Aug 5, 2015 08:24 PM
