help with tranny
help with tranny
I have a 97gxe auto with scer, y-pipe, and exhaust. Starting today i had problems with my tranny. It won't go in reverse, 1st gear is really weak, 2nd and 4th won't go above 2500 rpms, but 3rd gear runs fine. Wondering if anybody else has had similar problems or knows what i might be able to do to fix it. Maybe the tranny doesn't like the scer?...i don't drive it hard on a regular basis either. Thanks for the help
i dont know if this is it for the reverse problem http://www.jatan.net/tsbs/048497.pdf
thanks for the info, i'm checkin it out. If my tranny was gone, would it still be able to go through the rest of the gears though? One of my friends said it might be going into a "safe mode" by locking up after 2500 rpms. Not sure what this means though.
couldn't figure out whats wrong with the car so i'm takin it to balanced performance, they did the scer install so i figure its the best place to take it to...anyways, lurchdogg11, i have a vortech v1 scer...i haven't seen any other boosted maximas in the area, i'm currently in school at georgia southern and there's not many imports here at all...i'd be interested in going to some meets in atlanta if yall have any though
Mine did the same exact thing just before they all locked up. The only gear I had was third. It wouldn't roll through the gears, but rather just stay in third all the time. I had to get my tranny rebuilt after that.
well, got a uhaul truck and trailer and got the car back to atlanta and in the shop. Diagnostic test showed problems with low and high gears, as well as reverse, bad probs...anyways, gettin the tranny rebuilt. The mechanic said he could calibrate the vb for firmer shifts (similar to the mobiltek vb mod?) any opinions on going this route? Also anything that would be good to do while the tranny is out to help prevent this from happening again?
Originally Posted by Fekz
How much is this costing you? just curious because after extensive reading on the org, ive come to the conclusion ill be replacing my tranny when the differential bearing goes soon or later.
its cheaper for the manual tranny
Originally Posted by Lurchdogg11
Hey man, what kind of SCer do you have?
We have quite a few boosted Maxes in Atlanta, I'm surprised to see another!!!
I saw a rosewood 4th gen with CF altezzas but only on the outside shaved trunk. looked kinda good.
Maybe a tranny shop would take it apart and look at it for you, that is a weird problem, and if specific gears act up then its a good sign the tranny or could be a problem with your clutch disk, pressure plate, or the release bearing.
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
pktaske
Sep 4, 2015 08:40 AM
