cv joint carrier bearing
does anybody now how to break the carrier bearing loose on the passenger side on a 95 se auto. I got the 3 bolts out easy it just doesn't want to break loose thinkin about puttin the torch to it but I might destroy the bearing as well.
The two steel parts often fuse themselves together. I took a chisel (and then a flat head screwdriver) to the crack that separates the two and gradually worked them apart. Took me a blasted hour though!
what about pulling the passenger side first on the joints or does it not matter can I pull either side. Chilton's says you have to pop the driver side through the transfer case from the other side seems like a pain.
litch
123
01-04-2024 07:01 PM
220k+ A32
25
10-03-2015 09:09 PM
Andy29
09-29-2015 05:32 AM
