Low Fuel Light
Old Nov 14, 2004 | 07:35 AM
Kinger402's Avatar
Low Fuel Light
Just a quick question about the Low fuel indicator light.
I have tried to run my gas tank incredibly low to see when this light goes on. It is the small little light on the gas guage. But it never goes on. Is my bulb gone..if so how do i replace this. Or do only certain max's come with this option. Also a side note..how do u activate the low washer light if you do not have the cold weather pkg. 95 Max.
Old Nov 14, 2004 | 07:39 AM
njmodi's Avatar
Do I get a tax break?
1. It might be your bulb - the low fuel light was standard on all 4th Gens. No real way to know if its the bulb or not unless you replace it. You have to pull the instrument cluster out to get to the bulb (same as getting to any gauge backlighting bulb).
2. I think you need to get the washer reservoir with the sensor built-in - not sure about the wiring though (i.e if its pre-wired or not).
Old Nov 14, 2004 | 07:40 AM
99 SE-L
Dont drive with the low fuel light yesterday me and my freind 99SEMAXIMa WERE DOING SOME 0-60 RUNS IN HSI MAXIMA AND THEY WERE AWFUL HIS LIGHT WAS ON THEN WE GO ON THE HIGH WAY AND AFTER SWITCHING GEARS HIS RPMS ARE GOING CRAZY FELT LIEK CLUTCH SLIPPAGE THEN WE WEWRE DRIVING AND THE WHOEL CAR WAS JERKING FINALLY HE PUTS IT IN NEUTRAL AND THE CAR SHUTS OFF WE WAITED LUCKILY CAR STARTED BACK UP AND WE WENT TO NEAREST GAS STATION DONT WAIT UNTIL LIGHT GOES ON BECUASE U COULD HAVE A PROBLEM
Old Nov 14, 2004 | 08:01 AM
Longboarderphil
you usually have 2 gallons of gas left when the fuel light comes on.
Old Nov 14, 2004 | 09:18 AM
95nissanMax's Avatar
yea it seems like my car loss's power if its low on gas. the rpms act funny. just not as smooth as it should be.
Old Nov 14, 2004 | 09:20 AM
mansurxk's Avatar
yeah its difficult to vaporize it with such little left int he tank, so the combust process becomes more and more difficult.
Old Nov 14, 2004 | 09:37 AM
Terran's Avatar
Here's how to activate the washer fluid light.
http://www.cardomain.com/member_page...259701&page=13
Old Nov 14, 2004 | 09:43 AM
Batxel's Avatar
blah
my low fuel light comes on about 1/6 - 1/8 of a tank. This light is more irritating than SES light. Get your bulb changed and don't run your tank down on purpose.
Old Nov 15, 2004 | 06:26 AM
mbenc's Avatar
i don't use the light it hasn't worked for some time now, now insted i depend on the trip meter. It works good, i know once i'm around 300 miles time to fill up. The needle goes all over the place in my max, when i'm full it's over the line, and when i'm down to .5 gal it almost covers the light.... not to be trusted.
95 auto max 123,785 miles
Old Nov 15, 2004 | 06:33 AM
SonicDust187's Avatar
I think I may have figured out the problem for most maximas with this. However first you have to make sure that the light bulb is good. Let me ask you something, when you fill your tank to the max how far past F does the needle go? And when you are below the 1/4 tank sign, how much gas will your car take until it is full?
Old Nov 15, 2004 | 09:50 AM
Kinger402's Avatar
Did the 95' Maxes come with the cold weather pkgs? Is there an actual Low Washer light on their dash.
Old Nov 15, 2004 | 09:56 AM
vortechpower's Avatar
My washer resivor that I ripped out has a sensor plugged into it. Never really used the stufff enough to see a low level light come on. I have the cold weather pack
Old Nov 15, 2004 | 10:27 AM
crazy97's Avatar
How many gallons are our fuel tanks?
Sorry I don't have a manual, bought the 97 used.
Chiltons manual doesn't say crap.
Old Nov 15, 2004 | 10:50 AM
SPiG's Avatar
SomePsychoGuy
There is 18.5 gallons in our fuel tank.
I have had a 95 and a 96 and neither really have the low fuel light come on. I know the 97+ come on but the 95/96 don't really. It could just be the bulb is out. It does not really bother me. I just get gas when the gauge is low. My dad's 02 dodge ram has a low fuel light and it beeps at you every once in a while. It does this at like at 1/4 tank though and it still has like 7 gallons or so easy.
Old Nov 15, 2004 | 11:27 AM
Jatan's Avatar
Mine comes on with about 1.5 gallons left in the tank, but I always fill up with 5-8 gallons when it gets just below the 1/4 mark and I calculate my MPG every 800-1500 miles by filling up all the way.
Old Nov 15, 2004 | 11:33 AM
njmodi's Avatar
to refueling when the guage is at 1/4 tank... Other than getting another 50 miles of driving before refueling, I don't see the point of waiting until you are almost down to the last drop to get refuel...the light is just a gimmick in my mind (mine works btw - there was virtually no gas in the car when I bought it) ... we already have a gauge (thats non-linear and inaccurate), so what makes the light any more accurate? - I am assuming the low-fuel light feeds off the same signal that signals the gauge....
Old Nov 15, 2004 | 03:28 PM
Terran's Avatar
How much gas have you guys put in. The max has a 18.5 gal tank and I've never put in over 16 gal, so I'm not at all surprised the light doesn't come on.
Old Nov 15, 2004 | 03:37 PM
Longboarderphil
Our gas lights do not feed off the same signal. My gas guage reads 1/8 of a tank when my gas light goes on. it used to read E when the gas light went on. but i know that i get roughly 320-340 miles per tank.
Old Nov 15, 2004 | 03:45 PM
maximaman10's Avatar
If it is not your bulb it is a sensor in the tank. My low fuel light doesn't work either. Pull the bulb out and check it with 2 wires to you battery. If the bulb lights, it is the sensor in the tank. The part is around $101.00 at the dealer. I just said hell with it and don't run it that low.
Old Nov 15, 2004 | 04:04 PM
Kinger402's Avatar
Thanks for all the replies about the low fuel gauge...but what about the cold weather pkg..where exactly is the light that would come on for low washer fluid..on a 95
Old Nov 15, 2004 | 04:18 PM
Terran's Avatar
It's on the dash. Should already be there so you just need that <$20 sensor (get it off the JRnissan site and use the "maxima" promo code). I haven't actually done it (yet) so I don't know where on the dash it is, but I'm sure it will be pretty obvious.
Old Nov 15, 2004 | 04:59 PM
Ant96GLE's Avatar
THE ONLY PROBLEM YOUR FRIEND HAS IS BEING AN IDIOT FOR NOT FILLING UP
Our tanks are 18.5 gallons, from then the light first comes on you have about 40 or so miles... I've driven with the light on for about that distance.. and filled upto 18 gallons..
Old Nov 15, 2004 | 06:44 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
'95-'97 should be within the strip of warning lights below the fuel gauge until '98, when the dash was mildly revised
'98-'99 it's just under the strip of warning lights under the temp. gauge.
here's the warning light layout on '98-'99
Left Side, under fuel gauge:
<Low Fuel><Door Open><Cruise><ABS><Brake>
Right Side, under temp. gauge:
<Battery><Oil><Washer Fluid><Seat Belt><SES>
I don't remember the warning light layout on '95-'97 dash's but I do remember on my sis's '97 Max, the low washer fluid light was in the strip of warning lights under the fuel gauge.
I don't have the cold/deluxe pkg. either but on a sunny day when the sun hits the dash, I can see a faint outline of where the light is. I'm thinking of doing this mod.
kjlouis
Nov 24, 2018 06:09 AM
Roymg
Sep 3, 2018 05:10 AM
cruce91
Sep 20, 2015 10:23 AM
Slamrod
Sep 3, 2015 07:38 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
