Clicking sound when i turn
Old Apr 16, 2001 | 09:45 PM
totochilla's Avatar
I know this problem was diagnosed in earlier post but search sucks.... anyway what does it mean when i hear a clicking sound when im turning fully to the left ant slow spreed?? It only happens when i turn to the left i think
Old Apr 16, 2001 | 09:56 PM
I30CeFiRo's Avatar
Hmmm...Busted CV boot? did you drop your car?
Old Apr 16, 2001 | 10:17 PM
Justin95SE's Avatar
CV joint
yah dude, probably the CV joint... got mine fixed, you can get it rebooted, some places wont do that b/c it isnt as much a guaranteed fix... more like a delayer of destruction of CV jointage. i think i paid 150 to get it replaced and it was 50 to get it rebooted... i wouldnt go to the dealership either, the were gonna charge me over 400 dollars for the parts.
Old Apr 16, 2001 | 10:38 PM
nizmo95's Avatar
Sounds like your cv boot man, If you want to get it fixed the right way take it to the dealership, but it will cost you a range of $300 to $800 depending on if its one or both sides that need the boot replaced. I had the same problem and take it from me the longer you let it go the worse its going to get and the more its going to cost you.
Old Apr 17, 2001 | 01:12 AM
max808's Avatar
Mine's making a small clicking noise too, but CV boot looks good. I30CeFiRo, did you get your CV changed? If so, where? Thanks.
Old Apr 17, 2001 | 01:15 AM
I30CeFiRo's Avatar
I took it to the dealership cuz it was under warranty. hey were you from man?
Old Apr 17, 2001 | 09:01 AM
Sonic's Avatar
Is it only when moving, or does it also do it when stationary? It its also doing it when stationary, it probably not the CV Boot, it could be the strut bearing. Did you jack up the front end of the car and rotate the wheel to inspect the entire CV boot?
Old Apr 17, 2001 | 09:31 AM
gtr_rider's Avatar
192.168.1.1
i brought mine to the dealer also and they put a new on, for cheap.
Old Apr 17, 2001 | 09:39 AM
dch95's Avatar
CV joint.
If it is allready clicking then the damage is probably done and would be too late to just reboot/regrease it.
Old Apr 17, 2001 | 11:09 AM
totochilla's Avatar
No its not when its stationary, its only when im turning slowly,
I didnt do anything to the car, i didnt drop it, jack it up or anything, I know i didnt hit any big potholes either, could it be from sharp turning-cuz after i installed my strut bar i was testing ti vigorously and the front sort of hoped a little????
Old Apr 17, 2001 | 11:16 AM
totochilla's Avatar
ONE MORE THING
what should i look for to see what the problem is SO I kNOW before i go to the mechanic becuz they seem to find more problems than there are?
Old Apr 17, 2001 | 04:56 PM
max808's Avatar
Mine's making only a small clicking noise when making full turns, like turning the wheel to the maximum. What do you think? I30CeFiRo , I'm from Honolulu too.
Old Apr 17, 2001 | 09:01 PM
pawn's Avatar
cv joints are a cheap fix if you do it yourself, like 150 a side, not to bad and its pretty easy too
Old Apr 17, 2001 | 09:50 PM
dch95's Avatar
Two things to look for........
ONE MORE THING
A split/cracked boot at each wheel (drive axle) and look for fresh grease on the inside of your front rims and usually all over struts/suspension parts.
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
LtLeary
Sep 14, 2015 12:33 PM
bennuss
Sep 11, 2015 05:55 AM
