P0300 code any ideas
multiple cylinder misfire usually indicates the plugs or coil packs. i've heard the '99 models are prone to coil packs going bad. i would ohm check all of the coils to see if they are in spec and go from there. or just replace all the coils and plugs and start fresh.
I figured he had already replaced any potentially defective coil packs - since he states, "coil packs arent that old"... I guess it all depends on what "that old" means and which coil packs were put in...
the coil packs are less then a year old. Brand new all new, replaced with parts ordered from jerry rome nissan.
I replaced the plugs started her up and the cel light went off within like 20 mins..maybe a bad plug....if it comes back I'll replaced the crank position sensor.
I just saw your other thread about a plug smelling of gas... you might have had a pad plug - or maybe the coil wasn't seated properly on the plug or the coil's harness needed a wiggle (all resolved during your R&R of the plugs).
