Oil dripping from spark plug
Old Nov 17, 2004 | 09:25 AM
Frank_Askew's Avatar
I have searched the FAQ's and the last 10 pages and have not found anythng on this problem. I was changing my plugs and standing in front of the engine the back right plug after removal had oil dripping from it. I cleaned out the plug hole with a paper towel and put in the new plug. I know that is a short term fix but what is the problem and how do I diagnose it farther.
Frank
Old Nov 17, 2004 | 09:51 AM
NmexMAX's Avatar
dot dot dot ...
You have bad blow by, you may need new rings. Maybe.
It's definately not a good sign.
Old Nov 17, 2004 | 10:07 AM
Stephen Max's Avatar
Or it could just be the valve cover seal over that particular spark plug hole.
Old Nov 17, 2004 | 10:09 AM
plurco's Avatar
no this is not too bad. You just have a bad O ringon your valve cover. I rolled like this in my car for a couple years. Any oil that would get to the plug due to blowby would be burned.
Old Nov 17, 2004 | 11:14 AM
Cool, thanks! I will start looking into getting that fixed.
Thanks!
Frank
Old Nov 17, 2004 | 11:39 AM
JoeB
I had the same problem. Turned out it was the oil seal on the valve cover.
Old Nov 17, 2004 | 11:40 AM
Broaner's Avatar
2060lbs and falling...
For me the o-ring was very difficult to get out. I ended up ripping it and couldn't get the rest out. I left it and used RTV to seal it up. All is working fine so far.
Miket2006
Mar 1, 2021 03:55 AM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
