gettin new clutch installed on monday....what else should i do or replace?
i just bought a EXEDY Stage 1 clutch kit.....i am gettin it installed on monday.....and i was wondering what else do i need to do besides resurfacing the flywheel?
should i do a tranny flush? change out the transmission fluid?
check axles, if they have torn boots and u have money to replace, do so since they have to come off anyway. If you have a y-pipe that needs installing, free labor
, get your bearing checked so it can be replaced just in case its almost dead or causing leakage, there are other bearings that the tranny connects to the axle with. I recommend replacing those, i hear if they are really worn it might cause leakage?
Originally Posted by zack342
slave cylinder, dust boot, throwout bearing
maynot have to replace Slave cylinder....but TO bearing dust boot is a good idea...tranny flush is a good idea.....may as well while its out
While the tranny fluid is out, throw some Redline MT-90 in there. Also if you can afford to buy a new flywheel, pick up a Fidanza. Check your seals as well to see if they are leaking or not.
Rear main seal.
I would replace it wether its leaking or not.
Just because its not leaking now, doesnt mean it wont leak 6 mo. from now.
Unless your doing the install yourself, better to pay the labor of removing the trans once not twice.
CorollaULEV
30
Aug 9, 2021 08:11 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
kirkhilles
Aug 8, 2015 10:53 AM
