People with gauges please come in!
Old Nov 19, 2004 | 10:15 PM
97WhtSE's Avatar
Ok i got my gauges today and instalation went smoothly. I bought the EL-GLow gauges off ebay and they look damn nice. One problem tho, i didnt take the needles out to put the gauges in knowing that the needles will be decalibrated and wont work properly. After i insalled them i checked and they light up nice but my rpm and speedometer seem to be messed up they jump around and not working properly. If i press on the gauge face the rpm does work properly so my question how can i tighten them more so the needle wouldn't rub and touce the gauge face? HAs anyone else had this problem? Should i superglue them on so they will pe perfectly flat and this way the needles are gonna work?
Old Nov 19, 2004 | 10:17 PM
NYC_Maxima97's Avatar
Just use some double sided tape, thats what I did, problem solved.
Old Nov 19, 2004 | 10:27 PM
97WhtSE's Avatar
Ok so just use some really thin double sided tape right?
Thanks bro will do that tomm.
Old Nov 19, 2004 | 10:43 PM
AntLis97's Avatar
i had the same exact problem ... i used crazy glue... but when ull want to take them off the glue will mess up ur original parts... so if u use glue just put it in small amounts (thats what i did)
Old Nov 20, 2004 | 09:39 AM
l3ftonm3's Avatar
you could sand where the needle gets attached to the cluster, i sanded mine down a bit so it stands higher up and it dosnt stick at all. i also did use double sided tape too
Old Nov 20, 2004 | 10:14 AM
Igobuk's Avatar
Use double sided Scotch tape available at Staples. It's as thin as regular Scotch tape but double sided. You can use it on the entire back of the gauges and then stick them on REAL good. Be sure to get the tape nice tight around the edges of the opening where the needles go so they'll sit especially flush around the needles.
ManualMaxima's Avatar
5th Gen till she dies!
i 5th that.,..use the double side tape...
Old Nov 20, 2004 | 12:01 PM
GodFather's Avatar
Made in Taiwan
i cut the original guage out the way then just snapped the new guage in place. i had to glue the stop pins that hold the needles in place though. good luck!
Old Nov 20, 2004 | 12:39 PM
some peopel do it the hard way!
Old Nov 20, 2004 | 01:43 PM
icedogg's Avatar
yup
i just put my gauges in like an hour ago...and I am having the same issue...
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mkaresh
Mar 12, 2018 06:48 PM
BobTX10
Oct 7, 2015 08:43 AM
