Wtf????
Old Nov 20, 2004 | 07:21 AM
chenzarino's Avatar
Wtf????
OK, so I got my y-pip put in yesterday, car was running mint all day, then last night I got on it a bit and the engine just cut off. Wouldn't start again. Checked all fuses, all good. ECU is throwing some codes as well
0802 -Crank Position Sensor
0102 - MAF sensor
0902 - ???
Car was running fine w/no problems, now wont start at all. MY only option right now is to take it to the dealer, which I'd like to NOT do. Can anyone help me??
Old Nov 20, 2004 | 07:38 AM
chenzarino's Avatar
Called nissan they say a bad crank pos. sensor will cause the car to do EXACTLY what it is doing. gonna replace it.
Old Nov 20, 2004 | 07:58 AM
Vyrus's Avatar
Those aren't related to the y-pipe anyways. There are 2 crank position sensors, 1 is easy to change, 1 is very difficult.
Good luck!
-Cyrus
Old Nov 20, 2004 | 08:38 AM
Andy13186's Avatar
I guess it was just coincidence that you had the Y pipe installed the day your crank sensor died..., that sucks
Old Nov 20, 2004 | 09:20 AM
chenzarino's Avatar
Any way to tell which one went? Or should I just replace them both?
Old Nov 20, 2004 | 09:31 AM
goodhead's Avatar
long shot but did you try resetign ecu via neg battery cable
Old Nov 20, 2004 | 09:42 AM
mansurxk's Avatar
Good luck!
-Cyrus
theyre both easy...the one on the bottom of the engine is difficult to locate without taking off the splash guard, but requires the same 10mm socket to open.
Old Nov 20, 2004 | 02:54 PM
chenzarino's Avatar
What causes them to go bad anyway?
Quickgtp
Aug 27, 2015 02:13 PM
vanebecker
Aug 17, 2015 08:24 PM
CIRCO
Mar 1, 2001 07:26 PM
yongjun
Jan 20, 2001 08:42 PM
