Help! Strut mount order, need info quick
Hey all I'm about to order some KYB strut mounts (car is lowered w/ 130,000 miles, mounts never changed). But here's a dumb question - do they come in pairs or sold one each?
http://www2.nisspartswholesale.com/p...rt=Strut+Mount
Every site I see they don't mention if they come in pairs, so I don't know if I should place one order or two. Thanks!
http://www.partznet.com/nissanhomepage.html Free ship
You might as well replace the strut bearings so you don't have to pay for an alignment if those need replacing later on. Don't see the strut bearings on partznet.com so you might try calling them to see if they have those
That is what I was told, and I noticed increased wear pretty fast on my nice and before this incident, very new Yokohama AVS-E100's. An alignment IS needed for the front when you change the struts.
Whoever took your money for an alignment after you had struts changed is a crook. Sears tried to do that to me once. Nissan Maximas do not have a caster or camber adjustment from the factory.
The only thing adjustable is the toe. And that is done at the tie rod end.
Unless the struts you buy are bent, or you have a bent control arm, you do not need an alignment.
http://www.tirerack.com/tires/tirete...eral/align.jsp
"Additionally the vehicle's toe is one of the most critical alignment settings relative to tire wear."
Originally Posted by JaTaN
You need alignment for the front (rear can't be aligned), but what ever makes you sleep at night...
Ant
The Frye
Sep 2, 2021 11:03 AM
trungg86
Sep 4, 2015 04:58 AM
