faced with a dilemma...need your help!!!
Old Apr 17, 2001 | 08:28 PM
Roman-dude's Avatar
OK, here is the question. I had a broken sunroof (but working sunshade) and had the sunroof assembly replaced. The day after I picked up a car (I picked it up after work) the aluminum things on the sunshade that slide on the sunroof railing broke- I only opened and closed it maybe 10-15 times, trying to test if it was really fixed. Anyway, I took it to a mechanic and he says that he'll replace the sunshade free, if I get a new one. (We never actually discussed who was to blame for the breakage as I did not want any confrontation over what I thought would be a relatively cheap part AND also because I thought that maybe my opening & closing broke it, even though it should not have).
Now that I am thinking about it- he had to take it out of the sunroof assembly, in order to put in the new assembly. And that's when I think he bent the clips, so that they broke the next day after a few openings (once aluminum is bent it breaks very easily).
Now, I am thinking of confronting him (I doubt that he'll give in too easily given that the cheapest sunshade I was able to find runs just short of $300).
Am I right in my intentions?
Thanks a lot
Roman
Old Apr 17, 2001 | 09:15 PM
1MAX2NV's Avatar
$300!!! Have you try Tacoma Nissan in Washington http://www.worldparts.com/tacomanissan/, Courtesy Nissan in Texas, Vester Nissan in NC or South point nissan http://www.southpointnissan.com/
Thanks a lot
Roman [/B]
Old Apr 17, 2001 | 09:18 PM
Roman-dude's Avatar
Thanks, I'll check the others, but the Courtesy wanted over $400! The reason it's so expensive is that it's either original Nissan or NOTHING!
Anyway, what about my question?
Thanks again
Old Apr 18, 2001 | 12:05 AM
BSwithTF's Avatar
Definitely should be brought up.
Thanks a lot
Roman
Although, usually when you come back to confront a mechanic in this situation (unless he's a nice guy) it will do little or no good. Never hurts to try though.
Old Apr 18, 2001 | 07:25 AM
Roman-dude's Avatar
Re: Definitely should be brought up.
Thanks. Does not anyone else have an opinion?
Also, I could always go to a small claims court as the last resort....
psing23
Nov 30, 2000 10:30 PM
bjf
Nov 28, 2000 03:09 PM
