can anyone tell me where the tek is to reset the ECU?
Old Nov 22, 2004 | 04:10 PM
jettech's Avatar
I've looked through the stickies with no luck. The one I found with a link to this tek took me to an oddball site.
Can anyone tell me how to reset the ECU codes or point me in the right direction?
Thank you
Old Nov 22, 2004 | 04:16 PM
chuckie311's Avatar
try this
http://www.brianv.net/mods/ecu/
Old Nov 22, 2004 | 04:19 PM
MDeezy's Avatar
I'm surprise you didnt see it in the how to's but.
to reset the ecu, by the accelerator is a plastic guard which is covering the ecu, take it out (2 platic screws)
then get a flash light (dont have to but it will help) you should see an opering with a screw and its protected by a plastic, you can puntcure through the plastic or peel it back. and then turn the screw clockwise till you feel resistance (stop for 2 secs), then turn it back couter clock wise till you feel resistance (stop 2 sec), then turn it back clock wise again and stop and look at your CEL, it should be flashing a code.
record the number of long puses and number of short pulses, remember or better write down that number example 4 long 3 short. then follow the step above again but end with the counter clockwise turn to reset the ecu.
come here check the stickes to find out what the code means.
good luck.
Old Nov 22, 2004 | 04:20 PM
MDeezy's Avatar
damn beat to it!
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
220k+ A32
Sep 22, 2015 03:08 PM
Colossus
Sep 9, 2015 05:46 AM
