Car won't go need help now
Old Nov 22, 2004 | 09:55 PM
RedlineVQ's Avatar
my car won't move. it's a 97 SE 5spd and i try to shift into any gear and it won't let me shift into the gear. Also when i can put it slightly into R it grinds my gears. I'm gonna lose it need help now! Please help
Thanks,
Robert
Old Nov 22, 2004 | 10:42 PM
RedlineVQ's Avatar
please help freaking out
Old Nov 22, 2004 | 11:32 PM
Maximeltman's Avatar
maybe clutch fluid leak?
Old Nov 23, 2004 | 11:50 AM
RedlineVQ's Avatar
how do u check the clutch fluid? I couldn't find it anywhere near the top.
Old Nov 23, 2004 | 12:40 PM
chuckie311's Avatar
its under the hood.on the drivers side should have a yellow cap on it. or maybe your clutch is bad
Old Nov 23, 2004 | 01:13 PM
5spd99seL's Avatar
The clutch fluid is located behind to the brake fluid. It is hard to see, but if you look over on the driver side and down the fire wall you will see it by the master cylinder.
Old Nov 23, 2004 | 03:20 PM
Pappa Grande's Avatar
Yup, you need a new clutch (unless you are lucky and your clutch fluid is low).
Old Nov 23, 2004 | 11:04 PM
RedlineVQ's Avatar
my clutch fluid was empty ( not that i know there was such a thing) and anyway when i poured it in the pedal still goes to the ground and i can't shift into gear unless the car is off
Thanks,
Robert
Old Nov 24, 2004 | 05:16 AM
Cutler's Avatar
Thanks,
Robert
New clutch or MC or slave cylinder is dead.....
Old Nov 24, 2004 | 08:04 AM
Ok. You need a haynes manuel. You must fill the clutch fluid up and then BLEED the system. There are two places to bleed the system. check www.Motervate.ca for an idea of the procedure. Right now there is no pressure in your clutch system, so the pedal is stuck to the floor.
First bleed the system. The clutch should then work. Then you have to check for leaks. You may or may not have a leak in the system. I had a similar experience, and merely refilling the fluid and bleeding the system solved the problem.
Old Nov 24, 2004 | 08:44 AM
NetFurie's Avatar
After you bleed and hopefully determine that you don't have any serious leaks, make sure to check periodically. I've had two seperate leaks.
One in the hose that connects to the slave cylinder. It was pretty major. I would lose enough fluid to bring the level from max to min after about 30 shifts.
The second is still occuring and is coming from the slave cylinder itself. This one requires me to top off the fluid about once a month. I'll get it fixed one of these days.
Old Nov 24, 2004 | 08:51 AM
NetFurie's Avatar
one other test after you bleed.
once you get the pressure back, push and hold in the clutch for about 30 seconds. If it sticks to the floor after 30 something needs to be replaced immediately. As long as your res is full when you try this you won't have to bleed it again right away.
Old Nov 24, 2004 | 09:39 AM
nadir_s's Avatar
vicodin ... gift of life
after u put in the fluid and seal the cap, start pumping it for a very long time and life should be restored to it.
u dont need to bleed it unless u opened it up first and then pumped.
Old Nov 24, 2004 | 10:05 AM
Is this true, even if his fluid got so low that air is in his clutch hydrolic system?
I never heard of this method before. Nice tip if it is true.
Old Nov 24, 2004 | 10:24 AM
Terran's Avatar
You could have a leak in the hose. There is a writeup on motorvate. I'm too lazy to link it right now, but If you can't find it later I will.
Old Nov 24, 2004 | 09:59 PM
RedlineVQ's Avatar
well the problme is i kinda drove around for awhile and it needs to be bleed
Old Nov 24, 2004 | 10:00 PM
RedlineVQ's Avatar
btw i am the king of clutchless stick driving and yes i know i'm stupid
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Btheman80
May 1, 2018 04:03 PM
BobMax
Aug 15, 2015 12:35 PM
