vehicle speed sensor?
Old Nov 23, 2004 | 08:45 AM
YellowOne's Avatar
just wondering if anyone here has had a p0500 code pop up? it just came up again on my car i have already replaced the sensor and the code still comes up just wondering if anyone had any idea what else could cause it to come up. connectors & harness looks ok, no corrosion. thanks
Old Nov 23, 2004 | 10:40 AM
hasei's Avatar
日産
I went through the same thing, a VSS code after replacing the sensor. I was able to fix it by taking out the instrument cluster and re-tightened speedometer screws. I don't know if this works for you, but it costs nothing and it is worth trying.
If this doesn't fix the problem, it may be something between speedometer and VSS. I tried this one first because there is a TSB on this (broken wire connection) and replaced a portion of VSS wire, but VSS code kept coming back.
In the worst case you may need to replace the entire cluster. I know at least one .org member fixed the problem this way.
Old Nov 23, 2004 | 01:19 PM
YellowOne's Avatar
thanks for the reply i try doing that in a few days.
Old Nov 29, 2004 | 02:17 PM
NetFurie's Avatar
I get this stupid code after it rains. Must be an exposed wire or something.
Old Nov 29, 2004 | 02:54 PM
hasei's Avatar
日産
I suppose it's possible. After all it's all electrical and hopefully your problem will disappear once it's cleared....
Old Nov 29, 2004 | 04:04 PM
Igobuk's Avatar
I have this code too, I just reset the ECU and it stays off for about 2 months before it comes back. Everything seems to work so I haven't fixed it. Some people have said it may affect cruise control but I don't use it so haven't noticed.
It's not serious, just a nuissance to see the SES light.
wingnut2006
Sep 19, 2015 06:13 AM
I<3 A32's
Sep 10, 2015 11:07 AM
sdotcarter
Sep 2, 2015 09:53 PM
