Part behind rotor, scraping rotor
Old Nov 24, 2004 | 09:25 AM
TJ_Max's Avatar
Paradox Systems Vendor
There is like a protective piece of metal directly behind the rotor...i hit a pothole and it bent into the rotor....now its like a loud screeching unless i get down and push that part away from the rotor, but a few little bumps and time, and it comes right back....what should i do? just replace the rotors altogether, is this expensive? if not im gonna jack up the car and try to bend it back really far.....
Old Nov 24, 2004 | 09:33 AM
MilesA's Avatar
The shield is made out of sheet metal, you can just bend it back into shape. I'd suggest taking the wheel off and bending the metal with a pair of pliars or similar tool. Bending it by hand you may not be able to exert enough force to bend it completely back into shape.
Old Nov 24, 2004 | 09:36 AM
Longboarderphil
Yea, just do what miles said, this happened to me on my 240sx. I didnt have to take the wheel off though, i just bent the crap out of it the opposite way
Old Nov 24, 2004 | 11:29 PM
ManualMaxima's Avatar
5th Gen till she dies!
yea my max fell of the jack stands, and landed on the jack, it kept the car off the groud and off my leg, but that was the only thing that got messed up. It bent that plate all up. since my wheels was already off i just bent it out of the way.
my front one is loose for some reason, after i changed out my struts and springs, it is loose *** hell now and makes sounds sometimes when i drive.
Old Nov 25, 2004 | 10:38 AM
TJ_Max's Avatar
ill try that.....use a metal bar to press it back off the rotor as far as possible.....
MR2 T'd
Jul 9, 2021 05:06 AM
AcuraLegend
Oct 17, 2016 08:47 PM
BkGreen97
Apr 2, 2016 05:47 AM
crazyespn
Sep 3, 2015 01:30 PM
A32goldylocks
Sep 2, 2015 06:39 AM
