#@$cking over torqued bolt.. ARGGH
Old Nov 24, 2004 | 12:41 PM
joesmith's Avatar
Anyone else had a problem with a over torqued starter bolt (the large one)? I tried using a 1/2" ratchet with cheater bar and impact wrench and it is still stuck. The bolt has never been removed, so it was over torqued at the factory. Ideas on getting it loose?
Old Nov 24, 2004 | 12:47 PM
A32Matt's Avatar
wow...you couldn't get it off with the impact gun? spray that bish down with WD-40 or PB Blaster and let it sit for a couple minutes and have at it. Just keep spraying or get a stronger impact gun.
Old Nov 24, 2004 | 12:51 PM
Igobuk's Avatar
You can also try heating it with a blow torch. You don't have to get it red hot or anything, just hot, like a minute or two. Once you get it hot, try the impact gun again.
Old Nov 24, 2004 | 12:53 PM
sterlingmaxima's Avatar
yes the blow torch technique works best
Old Nov 24, 2004 | 12:58 PM
Pappa Grande's Avatar
Use a breaker bar and a pipe.
Old Nov 24, 2004 | 01:01 PM
joesmith's Avatar
torch
I try it with a benzene torch, I hope that works. I'm going to try another impact wrench also. The wrench I was using was an older IR model, ~350 max torque.
Old Nov 24, 2004 | 01:03 PM
2 Da Max's Avatar
i just used a long *** pipe on the breaker bar
Old Nov 24, 2004 | 04:21 PM
ny96max's Avatar
i had to use a craftsman 1/2" drive breaker bar and a 4ft long steal pipe with me and my brother pulling on it to get mine free...
goodluck!
Ant
Old Nov 24, 2004 | 08:07 PM
amulla01's Avatar
goodluck!
Ant
damn is it that hard to remove the fuking starter?
Old Nov 24, 2004 | 08:12 PM
goodhead's Avatar
damn how u fit an impact in there? if you are using an ujoint+ extention make sure its a BLACK one not the chrome crap, or u must have a ****ty impact lol yeah 4' breaker bar did it for me
Mar 12, 2020 12:06 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
The Wizard
24
Oct 1, 2015 08:47 PM
dcam0326
Sep 18, 2015 04:52 PM
