do u need a camber kit for sprint springs?
Old Apr 18, 2001 | 10:26 AM
Ed F's Avatar
currently i have the H&R / tokicos setup...and i dont seem satisfied with the drop...still looks kinda high =/...so i'm planning on getting the sprint springs...i'm just wondering if i need a camber kit with it...thanx
Ed F
Old Apr 18, 2001 | 11:03 AM
sinewave's Avatar
Only your front-end mechanic will know for sure. Tolerences in machining can either cancel each other out or they can stack up, so the only way to know is to install the springs and then have him check it.
How much camber do you have now? My Eibachs gave me -0.70 degrees on the left and -0.75 degrees on the right. The factory recommended maximum is -1.0 degrees.
Find a place that will give you a 90 day warranty on the alignment and that will give you a written list of measurements, i.e., caster, camber, toe-in. That way, if you need to install camber bolts you won't have to pay for another alignment.
Old Apr 18, 2001 | 08:17 PM
dch95's Avatar
What are you going to do..............
Ed F
with your H&Rs?!?!
Old Apr 18, 2001 | 09:47 PM
teejnut's Avatar
Ed F
yeah what are u going to be doing with your h&r's???
Old Apr 18, 2001 | 10:23 PM
NickStam's Avatar
When i brought mine for alignment i was at -.90. I just need to the toe adjusted and no camber bolts were needed.
Apr 16, 2020 05:15 AM
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Pied
Sep 26, 2015 03:29 PM
