LED's in Hazard and rear defroster
Old Nov 25, 2004 | 10:59 AM
Gen8888's Avatar
The write up is down for the install of leds in the hazard and rear defroster. Ok do I solder the led straight to the brown contact points? Is a resister needed? Thanks.
Old Nov 25, 2004 | 12:04 PM
Gen8888's Avatar
Also when i pulled apart the hazard switch, alittle metal thing fell out, i dont know where it goes back so when you push in the hazard, it stays in. Does anyone know exactly where it goes. Thanks.
Old Nov 25, 2004 | 12:21 PM
ManualMaxima's Avatar
5th Gen till she dies!
yes you need to use a resitor. i think the bottom contyacts are the positive.....
Old Nov 25, 2004 | 12:28 PM
98blkonblk
Check out my L.E.D's on my car...
http://members.cardomain.com/ledmaxi
tell me what you think ;]
Old Nov 25, 2004 | 12:30 PM
dear god why do you go around and ask everyone to check your site out...okay we get the damn point. do it once in the 4th gen forum. Not every other forum and the how-to's like you did
Old Nov 25, 2004 | 01:21 PM
Gen8888's Avatar
Anyone? I dont know where this pin goes in the hazard switch.
Old Nov 25, 2004 | 02:54 PM
Visitingreality's Avatar
Use a multimeter. You do need resistors, if you don't use them you'll blow circuits.
Old Nov 25, 2004 | 10:59 PM
Igobuk's Avatar
When you have your switch open, there's a small triangular white plastic piece. It has two small grooves in it. The small pin goes at the tip where the two grooves meet.
The reason the switch doesn't return when pushed in is because it needs that little triangular piece to guide it on/off and it can't do that without the little pin in place.
The hazard button is annoying to put back together, just take your time as that little pin loves to fall out of place.
If you try the cruise control, be careful there too, it works totally different but also is annoying to put back together, but if you get this hazard done, the cruise will be cake.
Good luck.
matts95max
Apr 23, 2025 10:44 AM
minsbang
Sep 11, 2015 08:48 PM
intimidator
Sep 5, 2015 07:23 PM
jds22
Sep 4, 2015 01:52 PM
